Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 09-27-2006
jenweberfuller's Avatar
jenweberfuller jenweberfuller is offline
jenweberfuller is on a distinguished road
Question can you tell if keel is iron or lead
We are looking at a '68 Cal 34 with a 5 ft fin keel that is encased in the fiberglass hull. Is there any way to tell if it's iron or lead? The owner has no clue.
Old 09-27-2006
jerryrlitton's Avatar
jerryrlitton jerryrlitton is offline
99 FLSTF
jerryrlitton will become famous soon enough
Send a message via ICQ to jerryrlitton Send a message via MSN to jerryrlitton Send a message via Yahoo to jerryrlitton Send a message via Skype™ to jerryrlitton
Use a strong magnate maybe?
"The road to truth is long and paved the entire way with annoying bastards."
Barrow cam
Old 09-27-2006
pelicanl pelicanl is offline
pelicanl is on a distinguished road
iron or lead
try a magnet, if you can find a large enough one it should pull pretty hard if the keel is iron.
pelicanl
Old 09-28-2006
feetup feetup is offline
seeker
feetup is on a distinguished road
Lead or Iron
Pass by it closely with a hand held compass. Lead is non-magnetic, iron is magnetic. You may get faint deflection with a lead keel if there are steel or iron fastenings internally but a compass will spin and hold if within a foot or so of that much iron.
Feetup
Old 09-29-2006
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
Jen, what difference does it make? You're looking at an encapsulated keel, and whatever it is, it is. It's not like you are going to have to worry about galvanic problems, or painting it, or fairing it. If the boat suits you...that's what comes with it.
Old 09-30-2006
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
A large magnet or compass will tell you if it is iron or lead, but I'd agree with hellosailor about it being encapsulated. Definitely get a good survey with a competent surveyor that has experience with GRP sailboats.
Only difference is that a lead keel will denser and the boat will be a bit more stable, given the same size (volume) keels, as a lead keel will be a greater percentage of the boat's displacement than a equal size iron keel. If the keels are the same weight, a lead keel will be smaller, and produce a bit less drag than the same boat with an iron keel of equal weight/mass.
If you're new to the Sailnet Forums... please read this POST.
Old 10-02-2006
Thank you all for your suggestions....they are all very helpful!!
Display Modes
vB code is On
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Cal 34 1968 keel iron or lead? jenweberfuller Gear & Maintenance 0 09-22-2006 03:01 PM
Internal Ballast vs. External Ballast windship General Discussion (sailing related) 3 09-15-2002 04:33 PM
Winged Keels Pros & Cons OldGlory Buying a Boat 13 04-09-2002 05:51 PM
Dehler Optima 101 Iron Keel aasault Racing 4 12-30-2001 04:37 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
