What is the towing capacity of your truck? How much does she weigh?
My truck is about 4,000lbs, and I'm really not sure about the boat since I've seen different things listed - between 1800 and 2400 lbs.
Be careful with 2WD; don't want to back the rear tires into the water. I found a 4WD better for that reason. Most ramps I retrieve from require putting the rear tires in the water a little bit. You know how slimy those ramps can get, just be careful.[/quote]
The trailer does have an extension on it, so keeping the
wheels out of the water should be easy enough. I'll also probably only be launching from fresh water (I can get out to salt water from there), and there are no tides to deal with so the slimy goo should always be at about the same location and avoidable.
I've been posting a lot of messages asking about towing on different boards, and an average of about 8/10 people say I'll be ok. I'm only towing it just over 2 miles also since I'm close to the lake. I can craw home at 20mph the whole way if needed too!
I'll find out more when I try it out I guess.....
Tom
