- Quick Menu
01-30-2007
Opinion of C&C 27 as coastal cruiser?
Hi all -
another question..
any opinions on an older C&C 27? I plan to sail mainly in Boston / Cape Cod bay (probably no more than 30 miles from landfall), maybe weekend trip sometimes, and MAYBE some racing just for fun (not trying to place in first place)...
So - opinions? This is a first boat for me, so looking for something simple, maybe singlehand around the bay for a day...
Thanks
01-31-2007
The C & C 27 is a decent boat, a bit bigger than the Oday you asked about. They handle heavy weather reasonable well. There are actully 4 models.
The mark I and II are similiar but he II has a taller rig. The III is a much bigger boat, 27 ft 11 inches LOA. versus about 27' 4" for the other two. This one is the best of the group.
The IV came out about 1980 and was a newer design but smaller boat and probably had a diesel.
They all had balsa cored decks and almost all of them now have wet spots but a decent survey will turn this up. They also had mainly atomic 4 inboards which were a decent engine but getting a little old now.
Any one of them in good condition make a decent starter boat. You can club race them as well.
01-31-2007
Wandering Aimlessly
You might also look into the Pearson 28-2.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love. JCP
01-31-2007
As a C&C owner (alas, I now own two boats), I would be less reserved in my praise of C&Cs. They are better than "decent starter[s]," they sail well, are fast for their time and represent an excellent value. I am not specifically familiar with the 27 but would suggest that you try cncphotoalbum.com.
01-31-2007
The C&C 27 Mark IV (introduced around 1980) is actually the same boat as the Mark III with a few tweaks. What is oftened referred to as the Mark V is an entirely new, and smaller, design that was introduced in the early 1980's. The C&C 27 class association is an excellent source for information on this boat. I've provided links to the class association and a review from Practical Sailor. Good luck.
http://www.cc27association.com/
http://www.cncphotoalbum.com/reviews/c&c27.htm
01-31-2007
Great Boats
Originally Posted by 7tiger7
Hi all -
another question..
Thanks
The 27 Mark I is a great boat, being a smaller version of the legendary 30 Mark I. Do not consider the newer Marks as C&C cut materials and strength in the newer boats to reduce weight. The Mark Is are every sturdy boats, and quite fast. I think the C&C 27 Mark I is a much better boat than comparables from Catalina or other makes, and I'd say a good one should serve you well. When you get enough experience to understand what you bought, you won't be dissapointed. You might consider whether you can afford to move to a C&C 30 Mark I as the extra room and performance will allow the boat to satisfy you longer. The guy who bought my C&C 30 mark I 20 years ago still owns it...I should have kept it!
01-31-2007
I will second the positive comments on the C&C 27 and 30 MKI. These are well made, stiff, fast, and seakindly vessels that perform beyond their size. I am a 30 MkI owner and am continually impressed by the quality of design and build of these "good old boats".
You will find that C&C used better materials (they have stainless keel bolts) and very fine workmanship in their construction.
01-31-2007
Generally, stainless steel is a lousy material for keelbolts...
Keelbolts are usually sitting in water for long periods of time, and usually quite oxygen-deprived, since the water isn't circulating... so stainless steel will rust through fairly quickly in that situation. Galvanized steel bolts are stronger and usually a better choice for such a situation. Also, chloride stress cracking and crevice corrosion are serious issues with stainless steel keelbolts.
More expensive materials are necessarily better materials, as what is the best material is often determined by what the use is...
That said, I do like the C&C boats, and have sailed on the 27, 30 and 38.
If you're new to the Sailnet Forums... please read this POST.
01-31-2007
All I can tell you is that mine are bright and shiny and haven't been replaced.
01-31-2007
Thanks for all the tips guys, I seem to be getting a better idea of what sort of boat to get. I want to avoid the trap of just getting a bigger boat, I still think something around 27 is my best bet - small enough to singlehand whenever I want, large enough to weekend with a few friends.
I don't need the "best" boat around, but don't want the "worst" - I don't care about luxury, just decent quality - so I guess "mid-range" boats are my target.
C&C 27 looks pretty good so far - found one for $11,000 in maine, take a look:
http://maine.craigslist.org/boa/263180610.html
Seems to be alright... any thoughts?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
