Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 05-16-2007
saurav16's Avatar
saurav16 saurav16 is offline
saurav16 is on a distinguished road
Send a message via AIM to saurav16
Technical Plywood Core question
Hi,
Another quick question: If you are looking at a boat and the stanchions are loose and rusty water can be felt inside the cabin from the washers and nuts holding the stanchion on the underside, is it a good bet that the wood core along the deck has rotted out (its marine plywood)?
Old 05-16-2007
Gary M's Avatar
Gary M Gary M is offline
Gary M is on a distinguished road
A moisture meter is your best tool to determine water penetration and should be your first step.
Tapping with a plastic hammer or the handle of a screwdriver will give you some indication of mushy coring, but unless you are experienced at this you need a surveyor to look at it.
A leak here on it's own is not a great sign but is not conclusive.
Gary
Old 05-16-2007
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
I'm a pessimist. I'd say yes, given that most bolts aren't properly sealed around where they penetrate a deck, the deck may be damaged. The only way to tell is to unbolt stanchions and examine the deck under them. "Proper" design would be solid fiberglass in those areas, not just cored decking, to avoid this problem.
Loose stanchions and rusty water inside, also means the previous owner wasn't taking care of business and you need to check for other neglect.
Old 05-16-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Yup... the marine ply has probably started to rot...but you also have to check for water migrating along the core—since water can migrate along the fibers of the plies in the plywood... and go a long distance from where the water entered.
If you're new to the Sailnet Forums... please read this POST.
Old 05-16-2007
Sailormann Sailormann is offline
Here .. Pull this
Sailormann will become famous soon enough
There might not be any core that close to the edge of the deck. Look at the underside of the deck. If it is all the same level then it is (probably) either all cored or all solid. If there is a difference in levels, then the core ends where the thicker part ends...
Display Modes
vB code is On
Marine plywood VS. pressure treated (wolmanized) plywood duffer1960 Gear & Maintenance 8 03-03-2006 12:12 AM
Installing Deck Hardware Don Casey Miscellaneous 0 03-30-2003 07:00 PM
creating a loop in braided core line Sloop23_417 Gear & Maintenance 1 08-28-2001 09:34 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
