Hello,
First of all, thank you all for your continued support. The words of encouragement and advice are very much appreciated by Cindy and me. I am beginning to post what I wish someone had before we made the mistake of buying our C&C 121. I hope t will serve as a useful checklist for buyers as the potential purchase of these boats.
HULL DESIGN AND CONSTRUCTION:
Tartan and C&C boats are all designed by Tim Jackett. I do not know Mr. Jacketts credentials in this area. A knowledgeable buyer should ask to see them in writing. A knowledgeable buyer should compare these credentials with those of other designers. Just because something looks good, doesn't mean it will sail well or is built well.
Tartan and C&C boats are all made using hull and deck molds. The Tartan 3700, 4100 and C&C 110 and 121 molds were originally designed and manufactured for use in making boats from more traditional polyester resin construction. The structures, when made with polyester, are much thicker than those from the new
epoxy resin lamination.
Why is this important? If the manufacturer switches an existing polyester construction set of molds to be used with
epoxy construction with resulting thinner walls, there will be a lot of air space between these components when they are dry fit. A knowlegeable buyer should ask if the boat they are considering was designed to be manufactured in
epoxy in the first place, with thinner panels, and that the molds were designed for these tolerances so that when components are dry fit, there are no air gaps.
Much has been said about how much "stronger and lighter" the new
epoxy hulls are than the polyester builds. I can tell you that our
epoxy boat keeps cracking and bends so much that the rudder binds. If these are traits of increased strength, I'd rather have a weaker one.
As to weight savings, in comparing
epoxy to polyester, we were told that our hull would be 25% lighter than the same hull in polyester. The design weight of our boat is 14,100 lbs. We chose the optional shoal draft keel which added 600 lbs to the standard keel weight of 5,500 lbs. So the design weight of our boat is 14,700 lbs. When you take the keels out of the design weights, useful as the keel weights are well known as each one is stamped with the actual weight from Mars Metal, for comparing the weight of the rest of the boat, you learn some interesting stuff.
Desin weight without keel- Standard boat- 8,600 lbs
Design weight without keel- Our boat- 8,600 lbs.
US Sailing requires boats that want to do offshore racing to have scientific weight measurement as one measure of determining speed potential. Several C & C 121's have been weighed using this system. Below find two of these certificate weights compared:
2001 POLYESTER CONSTRUCTION STANDARD BOAT 17,224 lbs
standard keel.............................................. .......-5,500 lbs
net weight without keel 11,724 lbs
2002
EPOXY CONSTRUCTION SHOAL KEEL BOAT 18,912 lbs
shoal keel.............................................. ........... -6,100 lbs
net weight without keel 12,812 lbs
What does this tell you?
First, the designers weight goals are not able to be met in the actual manufacturing process... in the case of the standard boat it is 3,124 lbs heavier than designed or 36.3% heavier than the design weight without keel.
In the case of our boat, it is 4,212 lbs heavier than designed or 48.9% heavier than the design weight without keel.
This is an enormous miss for a supposed quality builder with refined manufacturing techniques. Or is it? When I informed them in early 2004 of this and politely told them they should probably change their advertised weights, they didn't, and to this day have not. It is advantageous to advertise stronger and lighter to an uneducated buyer. More advantageous would be to actually deliver it.
Second, our
epoxy boat actually weighs 1,088 lbs MORE than the polyester sistership. WHERE IS THE 25% WEIGHT SAVINGS?
You would think that with all this extra structural weight, it might not crack and keep cracking!
They sure are "cooking up" something at NOVIS MARINE and Tartan and C&C Yachts of Annapolis, but in our case, it sure isn't stronger and lighter.
My plan is to attempt to publish one checklist item each day based on our direct and personal experience.
Hope you all find this useful.
Best regards,
John M. Vito
