Rigs-cutter vs. sloop
rig
Today these terms are used quite loosely as compared to their more traditional definitions. Traditionally the sloop
rig was a
rig with a single mast located forward of 50% of the length of the sailplan. In this traditional definition a sloop could have multiple
jibs. Cutters had a
rig with a single mast located 50% of the length of the sailplan or further aft, multiple headsails and reefing bowsprit. Somewhere in the 1950''s or 1960''s there was a shift in these definitions such that a sloop only flew one headsail and a cutter had multiple headsails and mast position became irrelevant. For the sake of this discussion I assume we are discussing the modern definition of a sloop and a cutter.
Historically, when sail handling hardware was primitive and sails were far more stretchy than they are today, the smaller headsails and mainsail of a traditional cutter were easier to handle and with less sail stretch, allowed earlier cutters to be more weatherly (sail closer to the wind) than the sloops of the day. With the invention of lower stretch sailcloth and geared
winches, cutters quickly lost their earlier advantage.
Today sloops are generally closer winded and easier to handle. Their smaller
jibs and larger mainsail sailplan are easier to power up and down. Without a jibstay to drag the Genoa across, sloops are generally easier to tack. With less hardware sloops are less expensive to build.
Sloops come in a couple varieties, masthead and fractional. In a masthead
rig the forestay and
jib originates at the masthead. In a fractional
rig, the forestay originated some fraction of the mast height down from the masthead. Historically, sloops were traditionally fractionally rigged. Fractional
rigs tend to give the most drive per square foot of sail area. Their smaller
jibs are easier to tack and they reef down to a snug masthead
rig. Today they are often proportioned so that they do not need overlapping headsails, making them even easier to sail. One of the major advantages of a fractional
rigs is the ability when combined with a flexible mast, is the ability to use the backstay to control mast bend. Increasing backstay tension does a lot of things on a fractional
rig: it tensions the forestay flattening the
jib, and induces mast bend, which flattens the mainsail and opens the leech of the sail. This allows quick depowering as the wind increases and allows a fractional
rig to sail in a wider wind speed range than masthead
rig without reefing, although arguably requiring a bit more sail trimming skills.
While fractional
rigs used to require running backstays, better materials and design approaches have pretty much eliminated the need for running backstays. That said, fractional
rigs intended for offshore use, will often have running backstays that are only rigged in heavy weather once the mainsail has been reefed. The geometry of these running backstays typically allow the boat to be tacked without tacking the running backstays.
Masthead
rigs came into popularity in the 1950''s primarily in response to racing rating rules that under-penalized
jibs and
spinnakers and so promoted bigger headsails. Masthead sloops tend to be simpler
rigs to build and adjust. They tend to be more dependent on large headsails and so are a little harder to tack and so require a larger headsail inventory if performance is important. Mast bend is harder to control and so bigger masthead
rigs will often have a babystay that can be tensioned to induce mast bend in the same way as a fractional
rig does. Dragging a Genoa over the babystay makes tacking a bit more difficult and slower. While roller
furling allows a wider wind range for a given Genoa, there is a real limit (typically cited 10% to 15%) to how much a Genoa can be roller furled and still maintain a safely flat shape.
Cutters, which had pretty much dropped out of popularity during a period from the end of WWII until the early 1970''s, came back into popularity with a vengeance in the early 1970''s as an offshore cruising
rig. In theory, the multiple
jibs allow the forestaysail to be dropped or completely furled, and when combined with a reefed mainsail and the full staysail, results in a very compact heavy weather
rig (similar to the proportions of a fractional rigged sloop with a reef in the mainsail). As a result the cutter
rig is often cited as the ideal offshore
rig. Like fractional
rigs, cutter
rigs intended for offshore use, will often have running backstays that are only rigged in heavy weather once the mainsail has been reefed. Unlike the fractional
rig, the geometry of these running backstays typically requires that the running backstays be tacked whenever the boat is tacked.
Cutters make a less successful
rig for coastal sailing. Generally cutters tend to have snug
rigs that depend on larger Genoas for light air performance. Tacking these large Genoas through the narrow slot between the Jibstay and Forestay is a much harder operation than tacking a sloop. As a result many of today''s cutters have a removable jibstay that can be rigged in heavier winds. This somewhat reduces the advantage of a cutter
rig (i.e. having a permanently rigged and ready to fly small, heavy weather
jib).
Cutters these days generally do not point as close to the wind as similar sized sloops. Because of the need to keep the slots of two headsails open enough to permit good airflow, headsails cannot be pulled in as far as on a sloop without stalling out the slot. Since cutter
rigs are generally associated with the less efficient underbodies that are typical of offshore boats, this is less of a problem that it might sound. Cutters also give away some performance on deep broad reaches and when heading downwind because the Genoa acts in the bad air of the staysail.
