Hi all here she is, now I have to organize the survey.
LOA: 39’
LWL: 30’
Beam: 11’ 4”
Draft: 5’ 11”
Displacement: 19,000 lbs.
Ballast: 9,500 lbs.
Engine: Perkins 4-108
Engine Horsepower: 40
Engine Hours: 1200
Fuel: 80 gallons
Water: 80 galons
Holding Tank: 36
Internal Layout:
Starting at the bow is the
anchor locker, immediately followed by a generous sized v-berth. Below the v-berth is the
holding tank. Aft of the v-berth, to port, is the head. Across on the starboard side is a hanging locker with double doors. This forward area is nicely ventilated by a deck
hatch. Going further aft is the saloon area with L shaped settee and table to port, and a straight settee to starboard. The back of the starboard settee can also fold up to create a bunk bed sleeping arrangement. Lots of storage area is located below and behind these two settees. The saloon is well lighted and ventilated by a large deck
hatch. Aft of the saloon to starboard is the galley with double sink and three burner
stove/
oven. Across from the galley to port is a pantry, additional drawers of storage and another very large hanging locker. Aft of this area to port is the entry to the aft cabin. This space has a large chart table, more storage lockers and drawers and a final third hanging locker. The aft sleeping quarters can accommodate two people.
Galley
12V Refrigeration in rebuilt box with new insulation.
Unique holding plate box which forms the freezer.
Propane 3 burner
stove w/
oven (2 propane tanks)
Propane sniffer.
Hot Water Heater (120v and engine driven)
Pressure water system
PUR 80 3.5 gph watermaker
Great Storage
Navigation/Electronics/Electrical
Raymarine SL70C Color
Radar/Chartplotter mounted on swivel bracket visible from cockpit and chart table.
Navman Wind/Speed/Depth/Repeater
Icom 802
SSB/Ham w/factory mod for clipping
Pactor Modem
VHF w/cockpit speaker
Sailomat 601 windvane
Raymarine 1000 tillerpilot for use w/windvane
Stereo with Monitor Audio speakers & subwoofer
Xantrex 1500 watt
inverter
Trimetric Battery Monitor
Xantrex 40 amp
battery charger
Balmar 100 amp alternator
Balmar ARS-5 Regulator
420 ah gel battery bank
Orca LED Tricolor/Anchor
Living Space Features
Efficient
lighting from Alpenglow fixtures
Additional LED light fixtures
Beautiful interior woodwork and teak floor.
Dickinson Newport propane heater.
Brass clock and barometer set.
Hanging brass trawler lamp.
Updated interior cushion upholstery.
Four electric fans.
Rigging/Sails/Anchoring Gear
Full batten main w/3 reefs new in ’04 w/batt cars. Very good cond
Roller
furling 130 genoa new in ’06. Excellent cond.
Removable inner forestay and running backs.
Staysail new in ’06. Excellent condition.
Full symmetrical
spinnaker .75 oz. Fine condition.
Asymmetrical
spinnaker w/sock. Good condition.
Forespar
spinnaker pole new in ’06.
Dutchman boom brake.
Profurl
furling gear for genoa. New in ’04.
Forestay replaced with one size up in ’04.
Backstay (w/insulators) new in ’06.
Garhauer rigid
boom vang.
44 lb
Delta primary
anchor.
Manual
windlass.
150’ chain new in ’06. 200+’ nylon
rode.
Danforth stern
anchor, 30’ chain + nylon
rode.
Additional features
Hauled out 10/07- fresh bottom job and new cutlass bearing
Revere 6 man
liferaft.
Inflatable
dinghy and outboard.
Outboard motor hoist on
radar pole.
Kiwiprop 3 blade feathering prop.
PSS dripless prop
shaft seal.
Leather
wheel cover.
Emergency tiller.
Emergency rudder conversion for Sailomat.
Epoxy bottom job in ’03.
Spartite mast partner system.
New rebuilt starter in ’06.
Second bilge switch w/ high water alarm.
Raritan PHII head new in ’07.
Hard dodger that complements her
lines; no big boxy thing. Windows and covers new in ’03.
Cockpit Bimini
Propane BBQ
