Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 02-26-2008
bobmcd bobmcd is offline
bobmcd is on a distinguished road
Ketch vs Sloop?
I am looking at two 32 footers: Fuji 32 ketch and Aries 32 sloop. LOA are similar: 31'6" vs 31'10". LWL are 24'9" vs 26'. Beams: 9'10" vs 9'6". Drafts: 3'8" vs 5'. Dspl: 13,115 lb vs 15,000 lb . Ballast: 4635 lb vs 5000 lb. Sail areas are same: 470 sf. Hull designs are quite different: Fuji, designed by John Alden, has sharper clipper bow and cutaway forefoot on keel with full stern and wide transom. Aries, designed by Thomas Gillmer has Colin Archer form with full length full keel and canoe stern. Our intended sailing area is the SF Bay with occasional jaunts up and down the coast. No long distance passages in the immediate future. I have never sailed a ketch but don't see learning to handle three sails a big challenge. Any comments on these two designs and/or these particular boats will be greatly appreciated.
Bob
Old 02-26-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Sailor
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
Bob,
In this size range there's almost no good reason to ketch- or yawl- rig a boat. Unless you have a particularly low bridge to get under, or some other infirmity that requires small sails. Sure it was done a fair bit in earlier times, even extending into the early fibreglass era, but there are good reasons you don't see it done anymore on boats in this size range.
Generally with modern sail handling conveniences (furlers, self tailing winches, etc) the larger relative sail sizes on a sloop of this size are still easily managed. Also, mizzen masts and sail handling tend to intrude on the cockpit area in undesirable ways. Add to that the extra cost associated with equipping and maintaining two masts and their rigs, and most folks prefer the sloop or cutter.
As boats get larger, a better argument can be made in favor of ketch rigs for keeping bridge clearances lower and simplifying sailhandling.
Pacific Seacraft Crealock 31
Old 02-26-2008
rennisaint's Avatar
rennisaint rennisaint is offline
rennisaint is on a distinguished road
I mostly agree with John, much to my chagrin, you really don't need smaller sails on a 32 foot boat unless you are getting serious about single-handing in bad conditions. Also, on a 32 foot boat the mizzen boom will probably interfere substantially with the cockpit space. However, ketch's are IMHO way prettier boats...but the aries is a nice looking boat also... I guess I'd sail them both and see which you like more.
Hope that confuses you!
Old 02-26-2008
Valiente Valiente is offline
Valiente will become famous soon enoughValiente will become famous soon enough
I like ketches a lot, having a friend with one, and I think they've been overlooked as a good cruising design for older couples in the last 25 years or so, but a 32 foot ketch is just a designer's indulgence or folly if you wish. The deck will be tight, having so much rigging about, and there's little advantage in sail area or management as even a five-foot tall woman can tackle a no. 1 of a boat with a 15 foot J measurement.
Ketches make sense from above 38-40 feet up, in my opinion.
On the other hand, if it's above reaching slowly back and forth around an inland waterway, why not?
Old 02-26-2008
BlueWaterMD BlueWaterMD is offline
BlueWaterMD is on a distinguished road
But the Fuji Ketch is just sooooo beautiful!
Old 02-26-2008
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
Neither are especially good sailing boats, nor would either be a boat that I would consider for the changeable conditions that are typically found cruising on San Francisco Bay. I also agree with the above posts which indicate that a ketch rig makes very little sense on a boat under about 40 feet.
The following is a taken from a draft that I had written for another venue, but it does discuss the basics of various rigs.
The next topic in our ongoing discussion on selecting the ideal boat is rigs. Like most of the topics to date, there is no single universally ‘right answer’ when it comes to the topic of rigs. Boats are designed as systems and each of the various rig types have their purpose and are best suited to particular hull types, and applications. The quality of the design is also important as a poorly designed rig of any type can make for a miserable sailing vessel that is hard on the crew and the boat alike.
Cutter and Sloop rig
These are the most common rigs being produced today. In current usage these terms are applied quite loosely as compared to their more traditional definitions. Traditionally the sloop rig was a rig with a single mast located forward of 50% of the length of the sailplan. In this traditional definition a sloop could have multiple jibs.
Cutters had a rig with a single mast located 50% of the length of the sailplan or further aft, multiple headsails and in older definitions, a reefing bowsprit (a bowsprit that could be withdrawn in heavy going). Somewhere in the 1950's or 1960's there was a shift in these definitions such that a sloop only flew one headsail and a cutter had multiple headsails and mast position became irrelevant. For the sake of this discussion I assume we are discussing the modern definition of a sloop and a cutter.
Historically, when sail handling hardware was primitive and sails were far more stretchy than they are today, the smaller headsails and mainsail of a traditional cutter were easier to handle and with less sail stretch, allowed earlier cutters to be more weatherly (sail closer to the wind) than the sloops of the day. With the invention of lower stretch sailcloth and geared winches, cutters quickly lost their earlier advantage.
Today sloops are generally closer winded and easier to handle. Their smaller jibs and larger mainsail sailplan are easier to power up and down. Without a jibstay to drag the Genoa across, sloops are generally easier to tack. With less hardware sloops are less expensive to build.
Sloops come in a couple varieties, masthead and fractional. In a masthead rig the forestay and jib originates at the masthead. In a fractional rig, the forestay originates some fraction of the mast height down from the masthead. Historically, sloops were traditionally fractionally rigged. Fractional rigs tend to give the most drive per square foot of sail area. Their smaller jibs are easier to tack and they reef down to a snug masthead rig. Fractional rigs place a lower stress on their hulls and often get by with lighter rigging and hardware for an equal structural safety margin. Today, fractional rigs are often proportioned so that they do not need headsails that overlap the shrouds making them even easier to sail. One of the major advantages of a fractional rig is the ability, especially when combined with a flexible mast, to use the backstay to control mast bend and sail shape. Increasing backstay tension does a lot of things on a fractional rig: it tensions the forestay which in turn flattens the jib. Increasing backstay tension induces controlled mast bend, which flattens the mainsail and opens the leech of the sail. This allows quick depowering as the wind increases and so allows a fractional rig to sail in a wider wind speed range without reefing, or making a headsail change than a masthead rig, although arguably requiring a bit more sail trimming skills.
While fractional rigs used to require running backstays, better materials and design approaches have pretty much eliminated the need for running backstays. That said, fractional rigs intended for offshore use, will often have running backstays that are only rigged in heavy weather once the mainsail has been reefed. The geometry of these running backstays typically allows the boat to be tacked without tacking the running backstays.
Masthead rigs came into popularity in the 1950's primarily in response to racing rating rules that under-penalized overlapping jibs (genoas) and spinnakers and so promoted bigger headsails. Masthead sloops tend to be simpler rigs to build and adjust. They tend to be more dependent on large headsails and so are harder to tack and also require a larger headsail inventory if performance is important. Mast bend is harder to control and so bigger masthead rigs will often have a babystay that can be tensioned to prevent pumping and induce mast bend in the same way as a fractional rig does. Dragging a Genoa over the babystay makes tacking a bit more difficult and slower. While roller furling allows a wider wind range for a given Genoa, there is a real limit (typically cited 10% to 15%) to how much a Genoa can be roller furled and still maintain a safely flat shape. As a result, masthead rigged boats generally require larger sail inventories.
Cutters, which had pretty much dropped out of popularity during a period from right after the end of WWII until the early 1970's, came back into popularity with a vengeance in the early 1970's as an offshore cruising rig. In theory, the presence of multiple jibs allows the forestaysail to be dropped or completely furled, and when combined with a reefed mainsail, and the full staysail, results in a very compact heavy weather rig (similar to the proportions of a fractional rigged sloop with a reef in the mainsail). As a result the cutter rig is often cited as the ideal offshore rig. While that is the theory, it rarely works out that the staysail is properly proportioned, (either too small for normal sailing needs and for the lower end of the high wind range (say 20-30 knots) or too large for higher windspeeds) and made of a sail cloth that makes sense as a heavy weather sail but which is too heavy for day to day sailing in more moderate conditions or out of a sail cloth too light for heavy going. Also when these sails are proportioned small enough to be used as heavy weather sails, these rigs will often develop a lot of weather helm when being sailed in winds that are too slow to use a double reefed mainsail. Like fractional rigs, cutter rigs intended for offshore use, will often have running backstays that are only rigged in heavy weather once the mainsail has been reefed. Unlike the fractional rig, when the running backstays are deployed, the geometry of these running backstays typically require that the running backstays be tacked whenever the boat is tacked.
Cutters make a less successful rig for coastal sailing. Generally, because of their offshore intent, cutters tend to have snug rigs that depend on larger Genoas for light air performance. Tacking these large Genoas through the narrow slot between the jibstay and forestay is a much harder operation than tacking a sloop. As a result many of today's cutters have a removable jibstay that can be rigged in heavier winds. This somewhat reduces the advantage of a cutter rig (i.e. having a permanently rigged and ready to fly small, heavy weather jib).
Cutters these days generally do not point as close to the wind as similar sized sloops. Because of the need to keep the slots of both headsails open enough to permit good airflow, the headsails on a cutter cannot be sheeted as tightly as the jib on a sloop without choking off the airflow in the slot. Since cutters are generally associated with the less efficient underbodies that are typical of offshore boats this is less of a problem that it might sound. Cutters also give away some performance on deep broad reaches and when heading downwind because the Genoa acts in the bad air of the staysail.
Yawls and Ketches:
As I said at the start of this discussion, boats are systems and when it comes to one size fits all answers, there is no single right answer when it comes to yawls and ketches either. A Yawl is a rig with two masts and the after mast (the mast that is further aft or further back in the boat) is aft of the rudder. A ketch is a rig with two masts, the after mast is forward of the rudder. Either rig can have either a single jib or multiple jibs. When a Yawl or a Ketch has multiple jibs it is referred to a Yawl or a Ketch with multiple headsails. It is considered lubberly to refer to that rig as a 'cutter ketch' or 'cutter Yawl'.
I lump yawls and ketches together here because the share many similar characteristics. Ketches, in one form or another, have been around for a very long time. In the days before winches, light weight- low stretch sail cloth, high strength- low stretch line, and low friction blocks, breaking a rig into a lot of smaller sails made sense. It made it easier to manhandle the sails and make adjustments. Stretch was minimized so the sails powered up less in a gust and although multiple small sails are less efficient, the hulls were so inefficient that the loss of sail efficiency did not hurt much. Multiple masts, along with bowsprits and boomkins, allowed boats to have more sail area that would be spread out closer to the water. In a time of stone internal ballasting, and high drag in relatinship to stability, this was important as it maximized the amount of drive while minimizing heeling. In theory, multiple masts meant more luff length and more luff length meant more drive forces to windward. But multiple masts also meant more weight and much more drag. There are also issues of down draft interference, meaning that one sail is operating in the disturbed and turbulent air of the sails in front of it, which also greatly reduces the efficiency of multi mast rigs.
Yawls really came into being as race rule beaters. They are first seen in the 1920's as a rule beater under the Universal and International rules. They continued to be popular under the CCA rule as well. Under these rules, the sail area of jibs and mizzens were pretty much ignored in the rating. This popularized the masthead rig and the yawl.
There was a basis for not measuring the sail area of a yawl under these rules. On a yawl going to windward, the mizzenmast and sail generally actually produce more drag than they do drive. This is because the mizzen is sailing in really turbulent air and has to be over trimmed to keep from luffing which can effectively act as an airbrake. This is slightly less of the case on a ketch where the size of the mizzen is large enough to provide a larger percentage of the drive.
Downwind mizzens also are a problem. In this case the mizzen is forcing the main or foresail to operate in their bad air and so again the mizzen is not adding as much to the speed of the boat as they are taking away. BUT in the predominantly reaching races that were typical of offshore races of that era they offered a number of advantages. First of all on a reach the sails are not acting in the slipstream of each other and so each contributes a fair amount of drive for the drag produced. Also with the advent of lightweight low stretch sailcloths, mizzen staysails, which are great reaching sails, came into widespread usage in racing. Here again a ketch has the advantage of having a taller mizzen and so can fly a bigger mizzen staysail.
It might be helpful to compare yawl and ketch rigs to sloops. The broad generalities are that for a given sail area a sloop rig will generate a greater drive for the amount of drag generated pretty much on all points of sail. That means that a sloop will be faster or will require less sail area to go the same speed. Sloops are particularly better than Multi spar rigs such as Yawls and Ketches on a beat or on a run. A sloop rig would tend to be taller for a given sail area. This means it would be better in lighter air but it potentially might heel more, or need to be depowered or reefed sooner as the breeze picks up.
Sloops work best on boats with reasonably modern underbodies. Both are more efficient and so can point higher and make less leeway.
Ketch and Yawl rigs work best with heavier boats with less efficient underbodies such as full keels and deeply Vee'd hull forms. These hull forms often need a lot more drive and the hull is the limiting factor in how fast or how close-winded the boat will be. The yawl or ketch rig's lack of windward ability is less of a liability when placed on a hull that similarly lacks windward ability. Also, the ability of a ketch or yawl to carry more sail with less heeling moment also makes it a natural for a heavier hull form which often has comparatively little stability when compared to the amount of drive required to make a heavy boat move.
Much is made of the ketch or yawl's ability to be balanced to help with self-steering, to hove to, or the ability to simply sail under Jib and mizzen in a blow. This is one aspect that a traditional ketch or yawl has over a traditional sloop. It is not so true of modern sloops. Modern (especially fractional) sloops can be easily depowered and that reduces the need to reef. With modern slab reefing gear, reefing is far more easily accomplished than dropping the mainsail to the deck on a yawl or ketch. In a properly designed sloop balance is just not all that hard to achieve.
The performance of all three rigs, both on broad reaches and in lighter air, can be improved by the ability to carry kites of different types.
In terms of comfort at sea, ketch and yawl rigs push the weight of the spars closer to the ends of the boat which can increase pitch angles, albeit, while perhaps slowing pitching rates. The taller rigs of a sloop tend to increase roll angles while slowing roll rates.
Then there are structural issues. It is often difficult to properly stay a ketch or yawl rig as the mainmast backstay often need to be routed around the mizzen and the forward load component of the mizzen if often taken by the top of the mainmast. It is also often difficult to get proper aft staying on the mizzen of a ketch or yawl as well. These structural issues are particularly pronounced on Yawls where the mast is so far aft in the boat that on a traditional boat it is hard to get adequate staying base widths.
Many of the early fiberglass yawls were very poorly engineered. I heard the story of how the Bristol 40 became a yawl. It seems that Clint Pearson (who owned Bristol) had started to build a Bristol 40 sloop on order for a particular customer. As the boat was nearing completion the prospective owner bailed out leaving Mr. Pearson with bit of a problem. Almost at the same time came an enquiry about the availability of a Bristol 40 yawl for prompt delivery for a different person. Without hesitation the potential buyer was told that they happened to have a yawl that was almost finished and would be available in a few weeks. Bristol was building a 24 foot Corsair and they took a mast and rigging from a Corsair and used that for the mizzen. A block of wood was glassed onto the hull for a mast step and a hole cut in the deck for
