Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
  #11 (permalink)
Old 04-07-2008
cardiacpaul's Avatar
cardiacpaul cardiacpaul is offline
MarineSurveyor
cardiacpaul has a spectacular aura aboutcardiacpaul has a spectacular aura aboutcardiacpaul has a spectacular aura about
I'm not for or agin either boat. The 30ft hunter is a much larger boat than the 27 catalina.
(former owner of a C27 here)
that being said...
Don't discount the "crappy" (dirty) boat. a couple of cans of clabber girl and some soft scrub and a nylon stiff floor brush does wonders. quickly.
Don't shy away for the A4 either. It has about double the HP of a yanmar, and I've been on both, and the A4 pushes the hell a heck of a lot easier than the diesel in a 30ft boat does.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
  #12 (permalink)
Old 04-12-2008
AjariBonten's Avatar
AjariBonten AjariBonten is offline
Aquaholic
AjariBonten is on a distinguished road
Question Updates, Updates; with photos
Ok. I've pretty much eliminated the Catalina '27. It's just too small inside.
I'm focused on the Hunter '30. Spoke with the current owner today; took a closer look, and after some extensive online research; have a few more questions.
What I found out: I spoke with the widow of the PO. She knew very little; but I found out there is a possible family connection, so there may be a little wiggle room making it easier for me to get into this boat.
The year is not known exactly, she thinks it's a 1976. From my research it is no earlier than 1976, no later than 1978.
Ran my hand along the shrouds, no fishhooks, etc. they feel solid. Deck hardware is firmly set, no apparent looseness; but they do not look to have been re-bedded. (no ooze, etc.) If they were, it was an A+ job.
All of the instruments look to be original and in need of replacement.
There are two things that I question. The first is the keel joint. See the two pictures below:
I have seen a LOT of boats in my area marinas with this same apparent issue. Any insights?
The other is a less common issue from my observations; but I've read about it in a number of reviews of Hunters of this era. Apparently the hull "works" around where the shroud chainplates reside; and it "dimples" the hull a little bit.
On either side of the hull, right where the chainplate would be for the lower shroud; ther eis a slight deformation of the hull.
It is approximately round, about 12" across, and dimples in about 3/8" at the deepest.
Take a look:
When I was there the other day I only noticed it on the starboard side, and I thought it was the result of a crappy docking job. After seeing the issue on a couple of owner reviews I went back and found it at the same place on the port side.
It feels solid. I have not been able to get below to look it over yet. I got to "look" down below; man what a mess.
One review I read suggested possibly moving the chainplates to the outside of the hull; with proper backing plates; any opinions?
I know, there are a LOT of '30 boats out there; but I'm pretty sure I can get this one for 1/2 to 1/3 the $ of comparables. I'm sorely tempted to get it and make the best of it in any case, we'll see.
Thanks again for all of your help,
Fred
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
..... Gordon Bok
  #13 (permalink)
Old 04-13-2008
SVSnap SVSnap is offline
Hunter
SVSnap is on a distinguished road
keel joint
I just rebedded and reinforced the keel joint on my Catalina 30. It wasn't too bad really, West Systems helped a lot and made it pretty straight forward. But the quantity of water that oozed out of that one in the pic... it's gotta be coming from somewhere. There's either a huge cavity in there or free communication with the bilge or something. Looks worse than the 5 or so blown out but recoverable keel joints I've seen. I think if you started digging into it you'd find something terrible. Can't help on the dimple.... mystery to me.
Thanks!
Hunter
"Hank Monk"
Catalina 30 Tall Rig
Pensacola, FL
  #14 (permalink)
Old 04-13-2008
sailingfool's Avatar
sailingfool sailingfool is offline
There are a lot of nice 30's around from that area: Tartan, Pearson, Cal, C&C, Ranger, even O'Day. The best you can hope for in buying a boat is to get what you pay for, in this case hopefully you would pay very little and get at least that, very little. The dimples come from the hull being distorted by the rig tension. either the rig is too tight, or the hull is not adequately constructed, I would bet on the second for this boat.
Decide to spend $10-12k and buy yourself a boat you might be able to take some pride in, rather than thinking, "well it was cheap...".
Just my opnion.
SF
CS 36T
Need a bottom scrub...
  #15 (permalink)
Old 04-13-2008
Aquaholic
Just my opnion.
Well, that cuts right to the bone, doesn't it? I tend to think the same way myself; but I sometimes have a problem with patience, to my detriment.
Thinking about it, this boat will probably need to sit on the hard for at least one season while I work on it. In the same amount of time, I can probably save up an amount of money to make the difference between this boat and a well found one.
Ok, so let's take this conversation away from "Should I buy THIS boat?" and change it to; "What can I learn about this boat to help me evaluate boats I look at in the future?"
The keel question. Am I interpreting what I am looking at correctly? The line I see is where the keel attaches to the hull? So, the rust could be either from the unpainted top of the keel; or potentially from the keelbolts?
The hull question. I am pretty sure I know what is going on there. The question is; what would be a reasonable fix?
Thanks again,
Fred
..... Gordon Bok
  #16 (permalink)
Old 04-13-2008
Valiente Valiente is offline
Valiente will become famous soon enough
Those two pictures threw up more red flags for me than the parade on "Stalin Day".
If the keel is iron, then it's partially dissolved inside the fibreglass encapsulation. If the keel is lead, then the SS keel bolts are partially dissolved. Something has rusted and rusted badly, and is carrying that rust from inside the keel, or from holes in the bilge to the crack in the keel stub.
The joint has not only failed, I would suspect that if the boat didn't take on water when launched, that the keel might fall off.
If that dimple isn't moving, then it might indicate rot in the knees or the frames, which in that era might have been encapsulated wood...once water gets it and stays in, eventually you have to cut out the mush to good wood, scarf in new wood and re-glass, a job that in some boats involves partial dissembly of the interior furniture, which may be glassed into the frames.
Run away. Run away now. This boat looks finished to me. Plenty of fish in the sea.
Display Modes
vB code is On
Years that Hunter produced Cherubini Designs Brezzin Hunter 1 12-03-2007 08:13 AM
A New Hunter 49 and an Old Traditionalist dawndreamer Buying a Boat 22 01-01-2007 09:32 PM
Thoughts on a Hunter 37-Cutter? brodgers Buying a Boat 6 09-21-2006 10:06 PM
1976 Morgan 28OI any thoughts? Tequiza Terri Buying a Boat 3 08-04-2003 01:02 PM
The Hunter 420 Micca Hutchins Buying a Boat Articles 0 10-07-1999 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
