Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 04-27-2003
jlubimir jlubimir is offline
jlubimir is on a distinguished road
Buying a Sabre 38
After much agonizing and spousal negotiation, I have signed a purchase agreement for a 1988 Sabre 38 MKII- K/CB with a 33hp Westerbeke- fresh water boat based in the Great Lakes (other finalist was a Tartan 37). Are there any mfr. or model specific issues I should be aware of as we do the survey? Also, would like to hook up with other Sabre owners for sabre specific advice. thank you.
Old 04-27-2003
windship windship is offline
windship has a little shameless behaviour in the past
Buying a Sabre 38
jlubimir,
Make sure you don''t have to make a turn to starboard to get into your slip.
My best friend had one(just sold it last year)he loved it and so did I.You will too.You''ll see.
Dennis
Old 04-29-2003
Buying a Sabre 38
I know the prop is offset- is this a problem ?? I am "stuck" with a predominantly downwind apporach, a turn to stbd and docking on port side. I may consider backing upwind into the slip when it is extremely windy.
Old 04-29-2003
Buying a Sabre 38
jlubimir,
Is it possible for you to move to a slip to where you''d have a turn to port to enter your slip?
Backing into your slip is an option.She does steer well in reverse.
Dennis
Old 04-30-2003
Denr Denr is offline
Senior Nappy Headed Ho
Denr is an unknown quantity at this point
Buying a Sabre 38
This is not a problem if you learn its characteristics. The boat’s behavior when backing down is not noticeably different from any other boat without an offset prop. Sabres have offset props to eliminate prop wash over the rudder and so that the auxiliary engine can be mounted almost level in the boat. When mounting the engine nearly horizontal, the propeller is much more efficient compared to one that is canted downward 15 degrees. I still have the original 2 blade fixed prop and have no problems. You want some cheese and crackers to go with that WHINE!
Old 05-05-2003
Buying a Sabre 38
the only "WHINE" will be a vintage Cakebread Cabernet, but thanks for the input.
Old 05-15-2003
gknopp gknopp is offline
gknopp is on a distinguished road
Buying a Sabre 38
Im looking at similar boats Tartan/Sabre and I would be interested in exchanging some emails or talking to you about your search and thoughts. My email is gknopp@optura.net
Display Modes
vB code is On
Sabre 28 Fuel Tank RickFagan Gear & Maintenance 1 10-26-2006 02:08 PM
Sabre 32, 34 MkI, 34 MkII winslow59 Buying a Boat 6 04-15-2004 06:38 AM
Sabre 28 Repower smb Gear & Maintenance 2 11-10-2002 04:38 PM
Sabre 362 auxiliary power geyser Buying a Boat 0 11-20-2000 03:26 AM
Welcome to Buying a Boat messageboard Buying a Boat 1 09-14-2000 04:22 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
