Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 08-05-2003
PerryD19 PerryD19 is offline
PerryD19 is on a distinguished road
Information on C&C 34+
I''m interested on comments regarding the C&C 34+, 1990 vintage, especially its facility as a cruiser, its seaworthyness,durability etc. Also the pros and cons of rod rigging
Old 08-05-2003
sailingfool's Avatar
sailingfool sailingfool is offline
Perry,
If you haven''t you should join the C&C e-mail group and get C&C owner comments there - you''re more certain to hit the right people.
FWIW, as a longtime C&C fan, I''ve always appreciated C&C''s excellent execution of the RACER aspect of the racer/cruiser concept, for which I think they are the hands-down best marque. As for cruising, I guess it depends on what one means by cruising... The Landfalls as their "cruising" line seemed to also be good performers, however I consider C&Cs to excellently designed as coastal sailers. As much as I appreciate these boats, none were designed for long-distance passagemaking.
Old 08-05-2003
Silmaril Silmaril is offline
Silmaril is on a distinguished road
I have been a fan of the C&C line for many years. My dad had one of the 35 MK I''s and it was an excellent all around boat, well built if not too flashy. Not much wood on them, which is a plus from the maintenance point of view. Well constructed and thought out. At the risk of sounding like a broken record, make sure you get a survey done by a reputable, licenced marine surveyor.
As far as the rods are concerned, they have proven to be tremendously reliable over the years. The main areas of failure are at the "heads" which are the mushroom shaped ends that are the connecting point of turnbuckles and the end fittings. You should have these inspected by a qualified Navtec rep every few years. Hairline cracks have been known to develop at the heads. This can be fixed by "Re-Heading" the rod and use of a longer turnbuckle screw. The other area to look for trouble is wherever the rod takes a bend, particularly at the spreaders. Stress cracks can develop there too, but no easy solution other than replacement. And lastly, the rod does not take well to damage. I had a backstay damaged by being run over by a forklift during storage. The nicks and scrapes, while not seemingly bad, were what would have been the beginnings of catastrophic failure. No one took responsibility and I had to foot the bill on that one. Ouch!
The pros- less weight and windage aloft, extreme life if not damaged. Cons- costly to replace, and subject to failure from what may seem like insignificant damage.
Display Modes
vB code is On
Request boat comparison information on 4 boats FrankLanger Buying a Boat 16 02-27-2006 01:19 PM
Najad Information? kc_cmc General Discussion (sailing related) 0 02-17-2004 04:02 PM
Looking for information for a Snark Mayflower dawg General Discussion (sailing related) 0 12-05-2001 02:00 AM
eastward ho information please teric36 Buying a Boat 1 11-15-2001 04:15 PM
Information on Commodore sailboat debsailor General Discussion (sailing related) 3 10-10-2001 03:55 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
