Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 12-11-2003
flicker flicker is offline
flicker is on a distinguished road
Beneteau 35 types
On Yachtworld, I see a 35-foot Beneteau First 35, First 35s5, First 35s7, First 345, and a 34-foot First 325 and First 345. Are all these real models or just misnomers? And of those that are real, what are the differences between them? I noticed that most have drafts of 6 feet, but others seem to be shoal draft. Is there a standard draft for a given model?
Thanks,
Chas
Old 12-12-2003
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
Beneteau 35 types
Yes almost all of those are real models although I don''t believe that there is a 35s7 and I assume that the First 35 is either a 345 or a 35s5. They all came with a number os keel options.
Old 12-12-2003
maxcontax maxcontax is offline
maxcontax is on a distinguished road
Beneteau 35 types
I am half owner in a First 345 and can tell you a bit about it: Displacement is about 13000, draft is 6'', length is 34''5" and it is set up with tiller steering. It has a reverse transom, backstay, double spreaders, and a great cockpit with the traveller before the hatchway on a bridgedeck. The layout below is conventional, with v berth, aft double starboard, head aft portside past a galley, and the folding table in the salon is centred. We went in on this one after looking very hard at the new 311 and 331.
Old 12-12-2003
Beneteau 35 types
Thanks for the feedback,
I must say, I''ve always heard Beneteaus refered to with a subtle (or not so subtle) air of derision. But on this BB, it seems that some cruisers prefer them. That''s a high recommendation, in my view. How do they sail? Do they have good sailing performance? Are they easy on the crew? Are they sturdy?
Chas
Old 12-12-2003
Jeff_H's Avatar
Moderator
Beneteau 35 types
The answer somewhat varies with the model. I have quite a bit of contact with the Beneteau First 345, First 38s5 and First 40.7. I have been quite impressed with all three in terms of sailing ability and boat for the dollar. The 40.7 seems to be an amazingly sturdy boat with exemplary sailing manners. The 40.7 that I have been racing on just won the IMS Mid- Atlantics (as a nearly 4 year old pretty much box stock boat with something on the order of 10,000 ofshore miles) beating some very well sailed and prepared boats.
The other two also seem quite sturdy as well, although some of thier original details have not held up well. Beneteau uses Lewmar hatches and the plexiglas on the mid-80''s and early 90''s hatches does not seem to hold up very well on the Lewmars. I found the 38s5 an easy boat to short-hand or single-hand although the versions with the traveller in the cockpit would be easier to handle than the ones with the traveller on the cabin top.
Old 12-15-2003
Beneteau 35 types
My first-hand experience with our Beneteau First 345 is limited to a sea trial but I have had long chats with the fellow I purchased from, the boat is sea-kindly and capable and noted around this club for it racing record--which may be due to tiller steering which I find way more responsive in a competitive situation, and also hull design, combination of which makes it point high.
Generally, though, if you are looking at a used boat, there seem to be three kinds: the ones that are worn out and need everything replaced: take the purchase price times 2 and give yourself two seasons of changing out things to get it right. A second type has been "maintained"--when it was getting old, it was changed out. Take purchase price and add 10% to make it yours, and it is an ageing but solid boat. The one I bought had been "evergreened"--pro-active, loss-prevention type spending that has kept the boat better than new, because of upgraded electronics etc. They cost more but are worth more.
Best wishes with your search, maybe Santa can find you one
Old 12-15-2003
Beneteau 35 types
Thanks for the advice and the words of encouragement.
Chas
Old 12-15-2003
Beneteau 35 types
Old 12-19-2003
garywayne garywayne is offline
garywayne is on a distinguished road
Beneteau 35 types
You should understand that Beneteau makes 2 types of boats. The "First" series are generally more race oriented. The "s" in the designation means that Phillipe Starck, a French hi style designer, did the interiors. The 331 you were considering is the crusier series, used to be called Oceanis. These boats are heavier, have more storage, as you would expect in a cruising boat.
Display Modes
vB code is On
report + decision: beneteau 32s5 ktum6 Buying a Boat 7 07-08-2007 06:16 PM
Club Beneteau Florida Invitation Jeffrey123 Gear & Maintenance 0 09-11-2004 12:42 PM
Beneteau Club FLorida Invitation Jeffrey123 General Discussion (sailing related) 0 09-11-2004 12:40 PM
Beneteau vs Hunter SEC Buying a Boat 38 04-08-2002 07:26 PM
Hunter vs. Beneteau PASailor Buying a Boat 10 11-12-2000 07:04 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
