Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 05-04-2004
daveygo daveygo is offline
daveygo is on a distinguished road
Craizing
The whole bottom of a Beneteau 32s5 has the craize and has to be ground out and repaired. The cracks have not penetrated the laminate as yet. I am told by the yard that it is now weeping and a milky washed out liquid is oozing out and mineral in nature leaving a green crystalyne deposit in some of the cracks. In addition the craizing on one side has risen above the boot stripe about 5 inches and will ground out and also repaired. This is taken into consideration in my offer. I am now concerned as to what the nature of the deposit is and if craizing and delamination will occur in the future.
Dave
Old 05-05-2004
sailingfool's Avatar
sailingfool sailingfool is offline
Craizing
daveygo,
If you really don''t understand the problem, how have you "taken it in consideration in your offer"?!! Did you pull back $3,000 or $30,000? Which number if either will actually be enough?
Consider no one''s opinion on such a situation except your surveyor, and even then you have to be willing to accept some risk (think $$$)if you proceed even well advised. Beneteaus have solid glass hulls and a situation like you describe is something I''ve never heard of with such a boat. My advice is to run from this boat, quickly as possible - leave if to a newbie or a gambler. Understand that the seller has a solid knowledge of whatever the real problem and probable cost of repair is, and can/will drop the price to sweeeten the apprearance of the deal to you, as long as he stays well above his inside knowledge of value - repair costs.
Sorry to seem a nag, but someone may take a real bath on a problem like this. Check out http://www.yachtsurvey.com/structuralissues.htm to see how nasty hull failures can be.
Good luck.
Old 05-06-2004
Yodagwb Yodagwb is offline
Yodagwb is on a distinguished road
Craizing
DITTO
Display Modes
vB code is On
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
