I think that Silmaril hit the nail on the head, if you are looking for a
rig that is simple and requires the least amount of ''fussing'' then a masthead
rig makes sense because there is less that can be done to alter its sailing characteristics (without reefing or changing sails). This simplicity comes at the price that for any particular sail combination there is a vey narrow range of windspeed that works for that sail combo at least as compared to a fractional
rig.
For any given actual sail area, properly sailed a fractional
rig will offer better performance and be easier on the crew on all points of sail. The key phrase there is "actual sail area". When you look at race boats, many racing rules result in masthead
rigs getting an advantage in ''unrated sail area''. Masthead
rigs are a little faster in races sailed in a narrow range of conditions under rating rules that under penalize unrated area.
This means that in real life, if you are buying a boat mostly to go racing and want to race under a rule that underpenalizes overlapping
jibs and
spinnakers, then a masthead
rig makes sense as long as you can afford to sail with a larger crew and maintain a more expensive sail inventory. (The C&C 99 has a masthead
rig as a racing rule beating ploy more than any other reason.)
If you want to go cruising, or choose to race under a rule like the IMS rule (or to a lesser extent PHRF) that treats all sail area more fairly, then a fractional
rig would makes more sense.
I did want to comment on Silmaril''s points:
Silmaril says that "a masthead
rig is faster on all points of sail", all of the wind tunnel and actual in the field testing literature disagrees with that when taken on an absolute sail area basis. For a given actual sail area, fractional
rigs with non-overlapping headsails, are actually the most efficient sailing
rig meaning offering the best performance per square foot of sail area. So I think when Silmaril says that the masthead
rig is faster on all points of sail, it is not that a masthead
rig offers better performance for a given sail area, but as mentioned above it has a rating advantage under some racing rules. That advantage really goes away quickly in the case of rating rules that permit fractional
rigs that use masthead
spinnakers but then the smaller crew and easier handling advantage of a fractional
rig goes away as well.
I also disagree that fractional
rigs by their very nature need to be more complex. Racing masthead
rigs are argueably more complex if they are to match and the performance of a fractional
rig. While it is true that fractional
rigs benefit more than masthead
rigs from having a wide range of backstay adjustment. Backstay adjustment on a fractional
rig quickly powers up and down both the
jib and mainsail with one adjustment. Once you get used to having that tool it is very easy to use (Too much helm pull it in, too little speed, let it out) It is actually easier to use and far simpler than the combination of a babystays and adjustable backstays which is the masthead
rig''s equivilent of a fractional
rigs mastbend control systems.
With regards to running backstays, most traditional and modern fractional
rigs do not use running backstays, any more than masthead
rigs continue to use checkstays. It is only on boats that are designed with very bendy
rigs that runners are still employed to fine tune forestay tension but then again, masthead
rig boats with very bendy
rigs end up with checkstays which in effect are less forgiving running backstays. (Most bendy
rig frac''s can live without their runners but few bendy
rig masthead righs can live without their checkstays being handled.)
That said cruising fractional
rigs will sometimes
rig running backstays in heavy weather in much the same way that cutters and sloops with a storm
jib mounted on its own stay will
rig runners in heavy going.
Anyway, here is my reply to an earlier discussion on this topic. Much of it is similar to Silmaril''s points and it was aimed at a person who was not clear on the definition of the two
rigs.:
"These terms both derive from the point at which the forestay hits the mast. On a masthead
rig the forestay hits the mast at the masthead (top of the mast). Masthead
rigs are far and away the more common of the two
rigs. It came about as a rule beating method for racing sailboats. Under the CCA and IOR racing rating rules,
jib size was under penalized. This promoted small mainsails and big
jibs.
On a fractional
rig, the forestay hits the mast somewhere below the masthead (or a fraction of the overall height of the mast. It is not unusual to see fractional
rigs referred to as a 2/3 (Folkboats), 3/4 (J-24) or 7/8th’s (Triton)
rig, 90% (Farr 40).
Each
rig has it advantages and disadvantages. There are some big advantages to a fractional
rig for cruising and racing. For cruising you are dealing with smaller and easier to handle headsails Not only are the headsails smaller because of the shorter headsails but, because the headsails represent a smaller percentage of the overall sail area, you don’t need to have overlapping
jibs. The sail area is made up in the mainsail.
Fractional
rigs often have purposely designed flexible masts and, when combined with a backstay adjuster permits quick, on the fly, depowering of both sails. On either
rig, mainsails are easier to slab reef in a manner that results in an efficiently shaped sail for heavier conditions. On a fractional
rig that means that you don’t have to take the expense, complication, maintenance and performance hit of a mainsail
furler. Controlling mast bend you can often avoid reefing the mainsail or
furling the genoa as the winds build. Roller
furling genoas have notoriously poor shape when partially furled. The smaller
jibs of a fractional
rig rarely need reefing and when they do the fact that they are often minimally or non-overlapping results in a better partially furled shape.
Masthead
rigs typically have larger running sails and so can typically point closer to dead down wind. They are a little more forgiving. Because Fractional
rigs permit such a large range of easy adjustment they can be trimmed through a range of adjustments that results in a bigger range of speed both slower or faster than a masthead
rig of similar sail area. The limited adjustment of a masthead
rig means that you more or less live with what you have. Therefore a masthead
rig neither has the opportunity for going really faster and with less heel, or going all that much slower either (although
jib sheet lead angles are way more critical on a masthead
rig and require more skill from a performance standpoint than any other adjustment on either
rig) as a result if sail trim is not your thing, then the masthead
rig''s lack of adjustability would perhaps make more sense.
My biggest problem with Masthead
rigs is that you really need to carry more headsails and make more headsail changes. This is partially a function of the responsibility of the
jib for drive. If you take a Fractional
Rig 100%
jib on a 28-footer it might be 150 s.f. and its 150% Genoa would be 225 square feet. But on a masthead
