1969 C&C Redwing 30 Deck/Hull Joint - SailNet Community
post #1 of 1 Old 07-02-2013 Thread Starter
I refurbished my 1969 C&C Redwing last year. I found the deck to hull joint was a big source of water down below. I completely removed the rub rail to expose the joint and found the rub rail was acting as a gasket between the deck and hull joint. The cost of a new rub rail was too great and it would have put back a system that had failed. So I chose to eliminate the joint with fiberglass and epoxy. I feel this has given the boat new life and comfort for me and my passengers.
Has anyone else had problems with their deck to hull joint? I expect most Redwing owners must have this issue.
tigerzilly is offline
Tags
atomic4 , core , paint , redwing
help me with my hull to deck joint!! jaymckay Gear & Maintenance 6 11-13-2012 07:51 AM
Seeking opinions for deck and hull-deck joint repair gregor1234 Gear & Maintenance 8 04-25-2012 11:10 PM
Deck to Hull Joint voice3 Sailboat Design and Construction 9 11-03-2008 05:10 PM
hull deck joint ArgleBargle Sailboat Design and Construction 5 09-28-2008 07:45 PM
Split deck cap and leaking hull/deck joint alaskaboy Gear & Maintenance 2 01-04-2008 09:25 PM
HTML code is Off
