Mirage 24 main sheet traveler - SailNet Community
 1Likes
  • 1 Post By Chas H
post #1 of 6 Old 09-06-2013 Thread Starter
Senior Citizen
Chas H's Avatar
I read and participated in this forum at least ten years ago when I sailed C&C's but did not own one. I still do not own a C&C but I recently purchased a 1977 Mirage 24. So that's pretty close. When I'm at the helm going to windward and close my eyes she's all C&C!
I would like to install a Harken mainsail windward sheeting car system and new track. Have any of you sailors done same? I am sure I'll have to raise the new track due to the width of the car. Any suggestions would be appreciated.
Edited 9/15
I installed the Harken car and track last June while there was still ice on Lake Superior. The worst part of the job was overcoming the fear of drilling nineteen new holes in my boat. There was ample room between the bridge deck and hatch covers for the new track without adding a spacer to raise the track. The new track is positioned aft about one-half inch from where the old track was.
A tremendous difference in ease of trimming after tacking. It's much easier to keep the boat pointed in the right direction while adjusting the mains'l.
-CH
Chas H is offline
post #2 of 6 Old 09-06-2013
Re: Mirage 24 main sheet traveler
If I remember correctly there's a bit of a bridgedeck where the traveler is mounted. It should be a straightforward replacement.. the bolt spacing ought to be the same, the new track and car will work together and there should be clearance (vertically) for the car, but I suppose it's possible you'll need a spacer (Starboard, perhaps?) If the traveler is near the aft edge of the bridge deck then the added depth fore/aft of the windward sheeting car shouldn't be an issue. Do you have decent access to the underdeck for the fasteners?
Faster is offline
post #3 of 6 Old 09-06-2013 Thread Starter
Senior Citizen
Chas H's Avatar
Faster -
The track on the Mirage is recessed on the aft edge of the bridge deck. The top of the track is about level with the top of the bridge deck. The aft side of the center section of track is exposed. The problem may be near the ends where the track goes between the bridge deck and forward edges of the locker covers.
Fortunately access to fasteners is easy inside the cabin. A socket wrench with an extension will make holding the nuts easy. I'll need to hang from a tree with weights on in my pockets for a few days to lengthen my arms so I can turn the screws on the track while holding the socket wrench. Or maybe my chiropractor could put me on his rack.
-CH
Chas H is offline
post #4 of 6 Old 09-06-2013
Sounds like you need a friend (and a font advisor!!)
Yes, the recessed track mount may be a problem for the larger WS car.. Are you stuck on a windward sheeting car?? In my experience they are not all they're cracked up to be, and it's possible to rig a standard traveler in such a way it's accessible from where ever whenever... and you'd save a few bucks besides.
Faster is offline
post #5 of 6 Old 09-06-2013
Dog Ship's Avatar
Font.....I could actually read that from my couch Faster. I didn't have to get up.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #6 of 6 Old 09-06-2013 Thread Starter
Senior Citizen
Chas H's Avatar
I'm aging rather fast, so my eyes like more picas with serifs.
-CH
Dog Ship likes this.
Chas H is offline
Cabin Top Traveler and Main Sheet SpcAlan1 General Discussion (sailing related) 48 11-08-2016 02:41 PM
Main sheet slimsloslider Gear & Maintenance 8 04-13-2013 11:47 AM
Blown main sheet traveler car- need advice ASAP sailtobike Gear & Maintenance 11 10-11-2012 01:44 PM
EASYCAR main sheet traveler - The quest pedcab Gear & Maintenance 0 05-24-2010 03:26 AM
How loose is your main sheet while raising the main? legarots General Discussion (sailing related) 33 06-24-2009 04:26 AM
HTML code is Off
