c&c 35 mk3 - SailNet Community
post #1 of 4 Old 08-13-2014 Thread Starter
Bluenose1111's Avatar
c&c 35 mk3
Hi, I have been getting some water coming in just below the ice box on the cabin sole when on a 30 degree plus starboard tack anyone have any thoughts on this? Thinking it may have something to do with the ice box drain? Should this be draining to the bilge? Thanks!
Bluenose1111 is offline
post #2 of 4 Old 08-13-2014
jsaronson's Avatar
Re: c&c 35 mk3
I've got the same boat. No one seems to know where in the bilge the drain goes. Chances are if you are that heeled over that much that water is coming in along the toe rail. The bolts probably need to be tightened. The boat goes slow when heeled past 20 degrees. If you are not a member of cncphotoalbum.com you should join.
Joel
jsaronson is offline
post #3 of 4 Old 08-22-2014
Re: c&c 35 mk3
On mine the Ice box is drained via a small hand pump and hose to the sink.
I dont think there are any through hulls in the general area.
Uricanejack is offline
post #4 of 4 Old 09-12-2014
chef2sail's Avatar
Re: c&c 35 mk3
Mine drains into the bilge via a hand pump under the sink. Water intrusion may be as J said . Rail bolts
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
C&C 32 vs C&C 35 mk3 Bluenose1111 C & C 10 05-09-2014 03:01 PM
buying a Cal 27 mk3 lans0012 Boat Review and Purchase Forum 11 04-06-2012 07:35 AM
1979 C&c 27' (mk3?) scurvy Boat Review and Purchase Forum 14 10-15-2007 09:12 AM
mast compression 38 mk3 drillerkc74 C & C 0 09-04-2006 02:31 PM
Sabre 30 MK3 greatwhiteway Boat Review and Purchase Forum 1 01-27-2003 10:07 AM
HTML code is Off
