How to buy / fix :: C&C Mega 30 :: Cabin top cover - SailNet Community
 2Likes
  • 1 Post By olson34
  • 1 Post By SamSMcLaughlin
post #1 of 6 Old 06-12-2016 Thread Starter
Hello there all,
I bought a C&C Mega 30 a few years back, and it was missing the top cover into the cabin.
How to buy / fix :: C&C Mega 30 :: Cabin top  cover-cc-top-cover.jpg
I have been using a very not amazing plywood cover that tied down with line. Not the best solution. I was hoping to either buy a new one, or figure out how to make a mould and create one out of fiberglass. I do worry about strength with the make-it-my-self solution. Anyone out there have any advice?
Thanks.
Sam
SamSMcLaughlin is offline
post #2 of 6 Old 06-12-2016
Re: How to buy / fix :: C&C Mega 30 :: Cabin top cover
Lots of options here.
I see that 'half' the original pin hinges are still there. The other half disappeared with the hatch, presumably. Molding a replacement might be a bit tricky, but doable with the right skills, tools and supplies. It's a pretty tricky 'first project' in fiberglass work.
Since it was never intended to have a sliding hatch, I'd say you're stuck with the 'removable hinge' concept. I think my first attempt would be to get some 1/2" acrylic cut to size (with a good overlap) and then apply some gasketing to it so it might seal onto the shoulders of the companionway passage. Find matching, or replacement "lift-off" hinges.. plenty available if you can't find an exact match that would allow you to continue to use the old halves.
https://www.google.ca/search?q=lift+...HQtfBx8QsAQIKA
If you latched your companionway drop board in place with barrel bolts, and then connected your new 'lid' to that with a hasp it would be fairly secure.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
SamSMcLaughlin (06-13-2016)
post #3 of 6 Old 06-13-2016
HANUMAN
RobGallagher's Avatar
Go to the Cncphotoalbum.com and join the C&C email list. Ask there, maybe someone can send you measurements and photos of the original.
If it was me, I would fabricate something out of hardwood and varnish it.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #4 of 6 Old 06-13-2016
Ask nicely and someone with a sister ship might make a splash mold for you. Send 'em enough $ to cover the cloth an resin.
There are books (no batteries needed...) and likely UTube sites with guidance on producing your own hatch lid.
Loren
ps: IIRC the editor of GOB has a sister ship. This could then become a project article for the magazine.
pps: unless you are in witness protection, fill in your bio here about where you sail.
ordkhntr likes this.
olson34 is offline
post #5 of 6 Old 06-13-2016 Thread Starter
I always love how quickly a specialized community forum can get an answer (or three) to you. Thank you very much. I'll respond back to let you know how it goes. The acrylic idea had crossed my mind. I had also had the thought of getting a heat gun and trying to slump a piece over the opening to get a better fit. And the measurements and splash mold ideas are great, too. Thanks.
I'll update my profile with the location: Lake of the Woods, Kenora.
EDIT: I emailed Karen at GOB. I'll let you know what she says.
HipToBeSquare likes this.
post #6 of 6 Old 11-28-2016
I have a C&C Mega 30, with the cover.
It's not a flat piece, and would probably be difficult to replace well with anything flat, the original part is curved in about every direction. You could get it something like that to work with a bit of effort, other than appearances I'm not sure of the downside. I generally pull mine off and stow it before sailing, under way, the way it flips up and almost stays up while you get in and out is kinda asking to get hit in the head with it, and with it there, closed, it flips up easy enough that I'd be concerned about people leaning on it handling the jib sheets (and ending up falling into the cabin..).
But I'm sure if I was missing mine, I'd want to replace it, even with the complaints I have with it.
There is a yahoo group called mega30sailors, it is a restricted group and requires joining, and is pretty slow. But every couple months someone posts selling off a boat or parts.
Or, I might be willing to make a mold, if someone could explain how to do it quick and cheap enough. I've done some fiberglass work before, but never anything quite like that. And making a mold, especially for one time use, using glass and epoxy would be kinda expensive to make and ship. I don't know what else something like that could be made of. (and if you had a port side rear seat, the part that goes over the engine, I'd certainly be interested in a "trading" of molds if such a thing is practical).
cplunk is offline
Tags
c&c , c&c mega , missing , parts
Looking for a mast for a 30 ft C&C Mega cliffcarefoot General Discussion (sailing related) 6 08-14-2011 12:28 PM
How can I fix (at least sort of) lost fiberglass from hatch cover? norcalgal Gear & Maintenance 5 07-02-2011 11:50 PM
C&C Mega 30 vs ODay 25 Rockstar2011 Boat Review and Purchase Forum 12 05-24-2011 10:23 PM
26S Pop Top Cover JohnHV25 MacGregor 5 12-11-2008 11:03 PM
pop-top cover? goose327 MacGregor 6 04-17-2007 08:34 PM
HTML code is Off
