Blogs
Go Back   SailNet Community > Boat Builders Row > C & C
User Name
Old 12-11-2006
fireman181 fireman181 is offline
C & C 32'
fireman181 is on a distinguished road
C & C 25 mk11, mast rigging
Hi, I am a new owner of a 1983 25' Mk11, have been scraping the bottom and re painting. While the mast has been down, I noticed the bottom of the mast has 3 sheeves, while the mast head has only 2 sheeves??? What is the third at the mast base for??. Also, what is the best way to rig for a spinnaker, do I rig a double sheeve pulley at the mast head for a halyard and a topping lift, and how do I attach at the mast head..........any info greatly appreciated....Buck
Old 12-11-2006
sailingfool's Avatar
sailingfool sailingfool is offline
Fireman,
If you have not, you should take this question to the C&C email group, I would think you can find another 25 II owner who can help you out.
I'd expect the third sheave in the base is for the spinnaker halyard you don't have. You'll rig that halyard to a single block that has to hang from a crane/extrusion on the mast head that positions the block free to swing and above the forestay. There may be an opening in the mast about 2 feet below the head for the spinnaker halyard to run internally. The topping lift needs to run to a block about 2/3s up the front of the mast. Again, see if you can get measurements from the C&C board.
Old 12-17-2006
C & C 32'
Thanks, that is how it is run on a J 24 that I have been racing on........still getting used to larger boats...........
Old 01-22-2008
ahab211 ahab211 is offline
ahab211 is on a distinguished road
spinnaker sheeve
An Asymetrical spinnaker might be the way to go. Easy to set up!
Display Modes
vB code is On
HTML code is Off
Deck stepped Mast-Always Bad ? Mrs Mutiny Buying a Boat 23 02-01-2008 10:05 AM
which 38ft boat? bluewaterdreamer Buying a Boat 10 10-03-2007 12:54 PM
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 9 06-30-2007 12:48 PM
30ft Catalina BigRuss Buying a Boat 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
