05-01-2007
You should find one or two set screws under the paint of the strut. (look for a dimple, and you may be able to carefully open it up without doing too much damage)
Once loosened, you MAY be able to tap the bearing into place, however you will probably damage it since it's a fairly thin wall. My experience is it's tough getting a cutless bearing out even with the shaft removed (requires hack-sawing and vise grips), so my suggestion is to leave it in place if the shaft isn't wobbly. Sticking out 1/4" is doing no harm. If it really bothers you, cut the excess off with a hack saw.
