Blogs
Go Back   SailNet Community > Boat Builders Row > C & C
User Name
Old 05-29-2008
emptycooler emptycooler is offline
emptycooler is on a distinguished road
Yanmar SB8 diesel
I purchased a neglected C & C 26 this winter w/SB8 inboard. The boat has potential. I'm not familiar with diesels, so what kind of check list should I do first. The previous owner did not keep records of any type or could not tell me anything, just that it runs.
Not much room to fit through lazeret hatch, but found the pipe that comes out of the top of engine and ties into muffler was loose. Pipe is corroded to some extent (replacing?) or just retighten? Makes me wonder about other items to look for.
Looking for suggestions and advice.
Don
Old 05-30-2008
Captphil24 Captphil24 is offline
Captphil24 is on a distinguished road
Send a message via Yahoo to Captphil24
Don, Just some suggestions. Drain the diesel fuel tank, replace with new diesel. New fuel filter. I have a '75, 27 ft hunter. The engine has never had any work done on it. Sucker just runs and runs. When it is running, you might look for any exhaust leaks. I always keep the inlet valve closed when not on board, and check the cooling water outlet flow when I first start the engine. You could also replace the water pump impeller. It will need replaced some time and now might be a good time for you to become familiar with the procedure. Oh, yea. Change the oil. You may have to draw the oil up out of the dip stick tube. My engine has not drain plug.
Good luck.
Phil in FL
Old 06-02-2008
Phil,
Thank you for the helpful suggestions, I'm on a learning curve, but a fun and sometimes frustrating one at that. Does the SB8 shake at low rpms?
Don
Old 06-02-2008
cnc33voodoo's Avatar
cnc33voodoo cnc33voodoo is offline
cap'n chronic
cnc33voodoo is on a distinguished road
nvrmnd.mispost.
Old 07-15-2008
Capt Phil
Now that I'm getting more familiar with boat, it is a shame past owner let so many item slide and just put boat in water season to season.
Display Modes
vB code is On
HTML code is Off
Yanmar 1GM Diesel fuel consumption H216Sailor Gear & Maintenance 15 04-03-2008 08:17 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Fresh water flush Yanmar diesel bgotbaum Gear & Maintenance 3 07-24-2003 12:20 PM
Used Yanmar diesel???? Elusive III Gear & Maintenance 2 02-17-2002 02:30 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
