Go Back   SailNet Community > Boat Builders Row > C & C
Old 07-04-2010
Kiltmadoc's Avatar
Kiltmadoc is on a distinguished road
Question C&C stanchions
So, my boat now has 3 bent stanchions (long story), where do I find replacement tubing for the stanchions? How much of a "boat buck" do they cost?
Old 07-04-2010
Gary M's Avatar
Gary M is on a distinguished road
You might be able to straighten them. I did one last year that was bent. Took it off and put the base in a large vise with some padding so it would not mark. Just bent it back, worth a try.
Old 07-04-2010
Kiltmadoc's Avatar
So, I read you correctly, the stanchion cannot be separated from the base? If that's the case, then it's gonna be a bit of money for my boat partner. I got a look at the stanchions today, one is crimped pretty badly; 2 others are listing to the stern just a bit. It also looks life the safety lines need replacement since they are rusty under the white vinyl.
While we're at it, what's the best idea for new safety lines?
Old 07-05-2010
Drumroll30 is on a distinguished road
Stanchions are available at South Shore Yachts in Toronto.
Old 07-05-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
whoa.
Most stanchions can be separated from the mounts, and definitely the toe-rail mount C&C stanchions can. The mounts and "official" tapered stanchions for C&C boats can be found here:
Holland Marine Products
If the mounts are fine and it is just the stanchions themselves that are busted, if the stanchions are not buckled, you might be able to straighten them. they will never look perfrectly straight, unless you are very very good. For the time and effort you will invest in straightening them, if you can live without the stanchions having the C&C taper, find a local metal supply shop and have them cut you the new stanchions you need.
Old 07-05-2010
Gary M's Avatar
Generally the stanchion is welded to the base. The base is then through bolted and fastened with a backing plate. Just ake it off and put the base edge in a vise and carefully bend the stanchion to where you want it. If it is badly crimped then this will not work but sounds like it will for two of them.
Old 07-05-2010
All of the Canadian vintage C&C's don't have the stanchions welded to the bases. Check out the South Shore Yachts website, they sell all models of C&C stanchions (2 versions) and bases (at least 5 versions).
HTML code is Off
New Method for Bolting Stanchions to Deck? maccauley123 Gear & Maintenance 6 11-26-2009 03:22 PM
Need new stanchions (34ft. C&C) maureena5 Gear & Maintenance 8 04-19-2007 05:57 PM
Pearson 36 vs C&C 37 dnr Boat Review and Purchase Forum 1 11-16-2002 04:07 PM
life line stanchions HerbertFriedman Gear & Maintenance 1 12-09-2001 06:01 PM
Stanchions RobGallagher Gear & Maintenance 7 11-25-2001 05:09 AM
