Go Back   SailNet Community > Boat Builders Row > C & C
Old 02-09-2011
Figur8t is on a distinguished road
Rudder for C&C 24
I'm wondering if anyone has sources or recommendations to for replacing a rudder on a 1976 C&C 24. I'm looking at buying the boat but the rudder has a pretty significant crack running across the top of it and I'd just like to know what I'm getting myself into before finalizing my purchase.
Also as a follow up, is it hard to find parts for these boats and does anyone have some good recommended sources?
Thanks
Old 02-10-2011
captainmurph is on a distinguished road
C&C 24 Rudder
Without seeing the crack in the rudder, I can't say for sure, but I think your best bet might be to repair your existing rudder.
You might also want to check out the C&C owner's site: C&C Yachts - C&C Photo Album & Resource Center
Captain Murph
C&C24
Carib Dreamer
Old 02-10-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
Check South Shore Yachts...they have many C&C replacement parts. Rudders are expensive, may be better to rebuild if salvageable.
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 02-10-2011
HUGOSALT is on a distinguished road
Agree try to repair rudder, if you need to call in a fiberglass guy, consider the cost to repair in your
purchase price.
Rudder manufacturers/repairs:
Foss/Finco in Calif. 714 973-2878
FossFoam/Newrudder in Fl. 352-529 1104
Foss Foam/Newrudder has built rudders for many of the
boat manufacturers for many years, as well as custom
jobs.
Buying a new rudder is very expensive, is rudder stock
good, you could build new rudder around it if can't repair
original. Good luck, Hugo
Old 02-10-2011
Thanks for all the info. I was under the impression that it might be expensive to have one rebuilt. Here's a picture of the rudder for your interest. Maybe it's not even something that needs repair?
Old 02-10-2011
PaulinVictoria's Avatar
PaulinVictoria is on a distinguished road
How far down does the crack go?
To err is human. To arrr is pirate.
S/V Tangerine, 1979 C&C24
Old 02-10-2011
Good question. I'm honestly not sure how far it goes down.
Old 02-11-2011
Drumroll30 is on a distinguished road
Phil's Foils in Ottawa is another good place to rebuild your rudder, they quoted me $1200 to rebuild the one on my 1988 30 Mk II which is significantly bigger.
Old 02-11-2011
RXBOT is on a distinguished road
If you can't effect a repair yourself or get a reasanable repair estimate check price at Ruddercraft, still probably 600-1000 dollars at least. Perhaps a moisture check to see if the rudder is saturated would indicate if a small self repair is all that is needed.
Old 06-17-2011
pirateman54 is on a distinguished road
I had a new rudder made for my C&C 35 mkII by southshore years ago. 3500.00. After seeing your photo I would repair what you have. The reason i say this is getting a new rudder made for a C&C is a trip. The drawings are in canadian maritime mueseum. It takes 3 months and they made mine wrong three times.
HTML code is Off
S2 11 rudder DavidFB S2 0 05-17-2010 02:10 PM
c-30 rudder mmayo Catalina 4 06-08-2007 07:42 AM
Rudder stevenscott Gear & Maintenance 4 08-13-2006 11:11 PM
O''day 272 Rudder jcharde Gear & Maintenance 2 03-08-2004 11:51 AM
Rudder thomasstone Gear & Maintenance 0 12-20-2002 02:22 PM
