Go Back   SailNet Community > Boat Builders Row > C & C
Old 07-15-2011
ismwo is on a distinguished road
77 C&C 26 Prop information
So far cross my fingers, my current stock prop is in good shape. Not being a prop expert but knowing there is a great deal of knowledge in this forum; I was just wondering if there were better props available for my boat? Also does the C&C 27 use the same prop?
Thanks in advance for the interest.
Old 07-16-2011
AirborneSF is on a distinguished road
Sounds as if you are not sure about it, why? When I got my boat, also a 26, I had a speed boat prop on it. Still no speed, ha, ha.
Old 10-28-2011
Langlo06 is on a distinguished road
Need a little help hear, Just purchased 1977 C&C 26
in near perfect condition, however when looking over
boom at the cockpit end seems to be a piece missing.
As mentioned this piece is at the extreme cockpit end of the boom. Right now piece of hard plastic has been installed with what appears to be the original screw.
Anyway a pic of this could send it to me
to see exactly what missing and if I can find replacement
Thanks
HTML code is Off
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 07:52 AM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 2 11-28-2009 02:19 PM
Prop/Prop-Shaft Key Size? Skipaway Gear & Maintenance 7 07-29-2008 09:04 PM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
