Go Back   SailNet Community > Boat Builders Row > C & C
Old 10-01-2011
old-sailer's Avatar
1980 C&C 30 MK1 Hull 641
old-sailer is on a distinguished road
Does anyone know what this is?
Please look at the attached file and tell me what this type of rig is called.
I have seen this on a Jeanneau but no one seems to know much about it.
It's an alternative to having a traveler it appears.
Old 10-01-2011
RichH's Avatar
RichH will become famous soon enough
The proper name would probably be a - 'split base' double tackle .... @ (4:1) .
its ability to act as a traveller is very limited .... cant move this traveller to windward or 'drop' the traveller without having the boom also rise (but not as much as without such arrangement and only using the 'normal' in-line blocked mainsheet system). You're going to need a very strong VANG to make this common old-fashioned system 'work well'.
Old 10-01-2011
old-sailer's Avatar
Gratefully I don't have this setup.. but after seeing it I just wondered what it was.
Thanks for the info.
Old 10-01-2011
marianclaire is on a distinguished road
Have something similar on the MC. Not the best for sailing close to the wind. Dan S/V Marian Claire
Old 10-02-2011
Definitely not something that would replace a traveler... Oldsailer, if that's tempting you as a way to get around your mainsheet/bimini conflict I don't think you could stand behind the wheel without entangling yourself in that arrangement....
1984 Fast/Nicholson 345
Old 10-02-2011
A better pic. I raised the "sheet cam" off the deck. You pull down to disengage the sheet and it was very awkward down low. Dan S/V Marian Claire
Old 10-02-2011
SHNOOL's Avatar
SHNOOL is on a distinguished road
It's a poor substitute for a traveler. The boom is nearly always too far down while sheeted to center, and rarely sheets well enough to give you good way toward windward.
We used to call the one we had (small boat - Kells 23 coaster) a "double tackle" but yep, sounds like he nailed it.
Old 10-02-2011
old-sailer's Avatar
Gee.. you scare me... mind reader or what....
Ok.. so I've exhausted all options. So I guess I'm stuck with the traveler the way it is.
Old 10-03-2011
Windkiller's Avatar
Windkiller is on a distinguished road
Is this sort of the same rig? it's stock on my boat,(sorry about the picture it's the best I have of the main sheet rig
nice boat ass! | Flickr - Photo Sharing!
Old 10-03-2011
Windkiller's Avatar
same rig?
Okay here it is I just remembered how to put a picture right in the post
HTML code is Off
