10-12-2011
C&C Racer/ Cruiser
We attached a thru three way bronze ball valve to the thru hull leading to the raw water pump. When It is time to winterize I attach a hose to the fitting, and down into the antifreeze. I slowly turn over the engine till it draws the antifreeze through the whole system, water pump, strainer, engine, riser, water mufler and out the exhaust port.
Dave
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
