-   C & C (http://www.sailnet.com/forums/c-c/)
-   -   Atomic4 (http://www.sailnet.com/forums/c-c/79684-atomic4.html)
old-sailer 10-11-2011 06:30 PM
Atomic4
Go-hifreann-leat
capn_dave 10-11-2011 07:10 PM
Well you can call Don Moyer
Or follow my suggestions:
Most parts are interchangeable between early and late model engines. However, a few parts (particularly some of those used in fuel, ignition, and cooling systems) are unique to early or late models.
If you have an original engine from the mid-seventies or later, with an oil fill tube over the flywheel housing in front of the engine, you can be reasonably sure that your engine will require all late model parts.
If your engine does not have an oil fill tube over the flywheel housing, it may require a mix of late and early model parts. You will therefore need the following information before ordering:
1. To order ignition parts (including the "Ignitor electronic ign."), you will need to know if your distributor was manufactured by Delco (used on late model engines), or by Prestolite (used on early model engines). Prestolite distributors are distinctively smaller in size, and their condensers are mounted on the outside of the distributor housing.
2. To order cooling system parts, you will need to know if your engine has a thermostat housing (a small dome-shaped casting) located on the front corner of the head, nearest the starter. This thermostat housing would indicate that your engine has a late model cooling system.
3. To order carburetor parts, you will need to know if your carburetor is made of aluminum or cast iron. Aluminum carburetors were used on late model engines. All carburetors were manufactured by Zenith or Bendix, so the manufacturer does not help in determining your carburetor vintage.
4. To order gaskets, you will need to know (1) and (2) above, plus the shape of your transmission cover. Late model engines used a square cover, and early model engines used a rectangular cover with a curved top ("tombstone-shaped").
Also, look for a serial number:
On late model engines, the serial number is on a flat spot in front of a "boss area'" in the casting of the block, directly above the oil fill tube over the flywheel housing.
On early model engines, the serial number is on the front side of the block directly up from the starter.
CalebD 10-11-2011 07:35 PM
+1 capn_dave.
These engines come in many flavors of 'early' or 'late' models. Previous owners may have added various bells and whistles or not. You can only find out by looking at all the components of your engine or a maintenance log (if you are lucky enough to have one). Of course it helps if you know what you are looking at.
deniseO30 10-11-2011 07:49 PM
old = rubber band for power?
new= synthetic rubber band for power?
:Hides from A4 lovers:
CalebD 10-11-2011 11:02 PM
Denise,
Hope you are enjoying your 'jack hammer' diesel while we enjoy the quiet purring of our A4's! :g
old-sailor,
If your boat is from 1980 then chances are your engine is a 'late' model engine as Universal stopped making them around 1983 but you can't rule out someone swapping an older working motor for a dead motor.
The dipstick on both types of engines is located near the back of the engine as it is usually tilted down at that business end in both direct drive and 'V' drive applications.
The stuff that is 'early' vs. 'late' model engines capn_dave gave you a very concise review of.
I would look for the serial number as capn_dave describes to figure out if the engine block is 'early' or 'late' model, but with a boat made in 1980 I'd bet on 'late' model engine block.
Other components may vary. An 'early' model carb could be fitted to a 'late' model engine and a 'late' model carb can be attached to an 'early model one. Most A4 installations I've seen do not have an oil filter as a rule but you can add one if you like but this gives no indication as to 'early' or 'late' model.
As capn_dave outlined, the most important part of figuring out the 'early' vs. 'late' model stuff is:
1) distributor: Delco or Prestolite?
2) thermostat housing on head near flywheel: present or not?
3) carburetor: aluminum (5 screws hold it together) vs. cast iron (4 screws)
4) transmission cover: rectangular or 'tomb stone' shaped
Here is a 360 degree photo of a 'late' model engine as refinished by Moyer Marine: MoyerMarine
Other engine components that may vary are:
- fresh water cooled (FWC) or raw water cooled (RWC),
- one water pump required for RWC, two for FWC
- electric or mechanical fuel pump.
The best resource I have found for the A4 is here: Moyer Marine Atomic 4 Community - Home of the Afourians - Powered by vBulletin
Everybody likes pictures so post a picture of your A4 if you can.
deniseO30 10-12-2011 11:39 AM
Jack Hammer? lol
