12-14-2011
Junior member, rest old
Originally Posted by Ocarina II
The c&c smile is not the seam between keel and hull,but an athwartship (across the boat) surface crack some times several feet long running upwards(towards the topsides) just ahead of the keel. It is repairable, and as 'peas' suggested, West system G-flex has produced the best results.
This is the first time I have heard of this explanation. I have always seen the smile referring to separation of the keel and hull, most prominent forward and becoming narrower as you go aft. As noted above, torquing keel bolts to proper setting before filling and fairing will fix this. Torque settings depend on diameter of keel bolts which depends on boat and are available at C&C Photo Album website. For my boat, C&C30 with 1" keelbolts, this was 350 foot pounds. Clean out the crack between keel and hull, torque bolts, then fill. I did this several years ago and smile never reappeared. Just filling without torquing can be done, but you'll be doing it every year.
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
