C&C 30 mast step - SailNet Community
post #1 of 10 Old 03-07-2013 Thread Starter
Remember you're a womble
PaulinVictoria's Avatar
C&C 30 mast step
I'm sure I read somewhere that C&C replaced the wooden mast step with a metal (aluminium?) on the 30's to prevent rotting when it got wet.
I looked at one recently, a 1976 vintage, and it looked like this:
Is this one a "rotter"? Looks awfully like a large lump of wood there, as well as a big lump of aluminium. I can't remember if the wood actually felt soft where it is discoloured.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #2 of 10 Old 03-07-2013
Re: C&C 30 mast step
Could you tell if the mast was sitting on that wood, or is it just a trim around that aluminum shoe?
Faster is offline
post #3 of 10 Old 03-07-2013
Senior Smart Aleck
jameswilson29's Avatar
Pull those two wooden shims out and shine a flashlight beam just aft of the mast to see what the mast is resting on. I looked at a C&C 30 with a warped original wooden mast step that looked a lot like that one.
jameswilson29 is offline
post #4 of 10 Old 03-07-2013 Thread Starter
Bit difficult to do that since a) It's not my boat and b) It's a 95 minute ferry ride and an hour drive away
I guess I will wait and see if any actual C&C30 owners can shed any light on it.
Orange Crush
1974 C&C27 MkII
post #5 of 10 Old 03-07-2013
jsaronson's Avatar
check out cncphotoalbum.com Its the best source for all things C&C
jsaronson is offline
post #6 of 10 Old 03-07-2013 Thread Starter
Yep, I already use that site extensively as a current C&C owner, there are some photos of the mast step replacement process, but they only ever seem to remember to take photos once they are going on it and have already hacked most of it away. Presumably they stand back and think, oh crap, I meant to take photos of this
Orange Crush
1974 C&C27 MkII
post #7 of 10 Old 03-10-2013
I'm going through the same issue this spring on my C&C 30. Looks like the same situation. Plywood stringers under the oak block, though mine is a 74. C&C resource page has a good picture of this. Not to bad a repair just a pain.
DanforthYachts.com is offline
post #8 of 10 Old 03-10-2013
Junior member, rest old
msmith10's Avatar
The problem isn't the block of wood you see under the aluminum fitting, although that may need to be replaced also. The block of wood sits above the bilge on crosswise frames which are wood, and may be covered in glass. It's those frames which can rot out and need to be repaired. You need to remove the block of wood you can see in the photo to assess the integrity of the true mast step-- the frames in the bilge which hold all that stuff up.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #9 of 10 Old 03-10-2013 Thread Starter
Is there a way of looking/checking without pulling the mast and dismantling the whole area?
Orange Crush
1974 C&C27 MkII
post #10 of 10 Old 03-13-2013
msmith10's Avatar
Not really,although you may be able to get a sense of it. There is a narrow (8") floorboard in the C&C 30 immediately aft of the mast step. Lifting this gives you access to the aftmost frame supporting the mast step. If this is in bad shape, you can assume the others (I think there a 2 others) are also.
If it looks ok and is solid to probing with an awl, I might let it go until the next time the mast is pulled. The rest of the dismantling job is easy.
Mark Smith
msmith10 is offline
Help with mast step pin(?) Lubrdink O'Day 6 12-18-2011 01:54 PM
Is there a step by step for a stepping of the mast? Skipper Joe Gear & Maintenance 5 07-15-2009 07:45 PM
How often should I step my mast doons60 Gear & Maintenance 7 05-28-2009 12:58 PM
Need new mast step dflyin1 Gear & Maintenance 2 03-24-2008 05:44 AM
N27 Mast step? russ1302 Newport 2 08-17-2007 04:53 PM
HTML code is Off
