C and C Mk2 portlights - SailNet Community
post #1 of 4 Old 03-27-2013 Thread Starter
I am hoping to replace the port lights on my C and C 35 MK11 with portlights that open. I am looking at Lewmar portlights but I dont know what size I need to order. Can anyone help me with this? Also does anyone have any suggestions on other makes of portlights?
Nathan Hesse is offline
post #2 of 4 Old 03-27-2013
Re: C and C Mk2 portlights
You'll have to check the Lewmar catalogue and know your existing port dimensions, and probably have to pick the next size up. This might be a difficult job because IIRC the MKIIs cabin has a fair bit of curvature.. Opening ports will only tolerate so much before they won't seal properly and the lenses can be under stress when closed.
It would update the boat considerably, though! Another option might be to simply replace your lenses but put a small opening port into the lens itself if its big enough, that would provide at least some cross ventilation and mean less finishing work as well.
Good luck!
Faster is online now
post #3 of 4 Old 04-13-2013
Are you replacing the forward ports or the ones in the main cabin? The forward ones can be replaced easily with beckson ports. I just replaced all the ports on my C&C 35 mkII. I had to have the deadlights for the main cabin custom made.
tyrohelmer is offline
post #4 of 4 Old 04-13-2013
jsaronson's Avatar
C&C owners are at cncphotoalbum.com. I'm sure someone has tried before!
jsaronson is offline
Portlights.. dieselboy Gear & Maintenance 14 03-09-2011 11:09 AM
portlights minkasi Gear & Maintenance 3 05-15-2010 03:21 PM
New Portlights itsme6582 Gear & Maintenance 8 04-30-2010 06:26 AM
portlights Dukeofpearl Gear & Maintenance 14 05-23-2007 10:42 PM
Portlights alps Gear & Maintenance 4 11-03-2006 12:44 PM
HTML code is Off
