34+ Cutless Bearing? - SailNet Community
post #1 of 3 Old 05-01-2013 Thread Starter
Does any one know the correct size cutless bearing for a 34+?
Thanks,
Dave
Dave Montgomery is offline
post #2 of 3 Old 05-02-2013
Re: 34+ Cutless Bearing?
Different bearing manufacturers have different sizes as they run different clearances, it is also important as to whether you intend to fit it as a press fit or a clearance fit. Best solution is to measure your shaft and the inside of the bearing carrier and then give those details to a bearing supplier. They will then provide you with one to fit your boat.
Fitting the bearing on epoxy as a clearance fit has a number of benefits and is now quite common practice for some bearings.
Kutter is offline
post #3 of 3 Old 05-02-2013
jsaronson's Avatar
Dave,
Try cncphotoalbum.com. That's where most of the C&C owners exchange info.
Joel
35 Mk III
jsaronson is offline
M-34 Cutless Bearing Removal dancrosswis@gmail.com Morgan 6 11-06-2013 04:12 PM
Cutless bearing question dln5000 Diesel 4 07-30-2011 11:30 PM
Removing the Cutless Bearing on a PSC 34 wsmurdoch Pacific Seacraft 0 12-03-2008 08:40 PM
Cutless Bearing Screws Redfish Pacific Seacraft 2 11-25-2008 12:44 AM
cutless bearing deniseO30 Gear & Maintenance 7 12-18-2007 05:40 PM
HTML code is Off
