Mainsail reefing - SailNet Community
 1Likes
  • 1 Post By Faster
post #1 of 5 Old 05-27-2013 Thread Starter
Mainsail reefing
Hi guys. Our 29 mkI has two reefing lines that run inside the boom and out the bottom at the mast. If it came out the top or side of the boom it would make some sense. Help please.
RodH is offline
post #2 of 5 Old 05-27-2013
Senior Pirate
TropicCat's Avatar
Re: Mainsail reefing
It's difficult to picture lines that run through the boom and exiting the mast as the two are only mechanically connected. I recommend you find an experienced local sailor to go through your sail controls and explain them to you
Tropic Cat
TropicCat is offline
post #3 of 5 Old 05-27-2013
There may/should be some cam cleats and levers where the lines exit the boom to 'jam' the lines once you've tucked the reef in.. our Selden boom is set up that way.
If there are no cleats there, nor cleats nearby on the boom or on the mast then they must be intended to run down to turning blocks on the deck and aft from there to the cockpit.
On one of our previous boats it was set up similarly, we added a small winch on the underside of the boom to aid in tensioning the clew reef line. It worked well.
chef2sail likes this.
Faster is offline
post #4 of 5 Old 05-31-2013
chef2sail's Avatar
They are intended to run down to the turning blocks and into the cockpit.
You should have one/ two rope clutches for easy reefing.
I will try and explain. Lines are led from the luff grommets which become the foot clew at each reef point through the end of the boom to the mast end of the boom to the turning blocks back into the cockpit through the clutches.
You should have a dedicated winch ( or sometimes the main sheet winch) on the port side which pulls in the reef line.
Its as simple as dropping the main halyard to the sail tack point, attaching the reef tack ring to the reef horn at the mast, tensioning the halyard , pulling in the reefing line attached to the reef clue on the luff. Make sure you do it in the proper order or you could rip the sail.
reefing
Practice this at the dock in calm winds.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #5 of 5 Old 06-05-2013 Thread Starter
Thanks Chef and everyone else. That's the way I ended up rigging them. I was hoping that I was missing something that would run the reefing line through the tack of the sail so I would not have to go forward to do it. Wishful thinking. Thanks Rod
RodH is offline
CDI mainsail reefing system sivilsld Gear & Maintenance 8 01-06-2014 12:47 PM
How to rig mainsail for Reefing preservedkillick Gear & Maintenance 5 09-22-2009 12:05 PM
Any experiance with the CDI mainsail reefing system? jgsteven Gear & Maintenance 5 02-11-2009 11:00 AM
Mainsail Reefing Classic30 General Discussion (sailing related) 25 12-17-2007 07:40 PM
Mainsail reefing dilemma aflanigan Gear & Maintenance 18 04-18-2003 03:58 PM
HTML code is Off
