Go Back   SailNet Community > Boat Builders Row > Catalina > C25 and 250
C25 and 250 For Catalina 25 and 250 owners
Old 07-15-2011
tklinck is on a distinguished road
Cool 25' Catalina Keel Bolt
I own a 1982 25' catalina, swing keel. I bought it from the original owner. He has had it on the same lake (Ray Roberts in Texas) since new. It is in good shape and never in salt water. I'm not sure if the keel bolt has ever been inspected or changed out. I removed the cover in the cockpit to reveal an enclosed fiber glass cover over what I think is the keel bolt housing. Can you tell me if this is the best access to inspect and possibly change the keel bolt. Or is there another way to inspect and ensure the keel bolt fails and my keel (or boat) doesn't go crashing into the depths of the lake/ Thanks for you assistance tom
Old 07-16-2011
jjablonowski's Avatar
jjablonowski is on a distinguished road
Check Cat25 specific Web site
Lots of discussion about swing keels here: Association Forum - Catalina 25 Specific Forum
Joe - Catalina 25
Old 09-10-2011
captnkev25 is on a distinguished road
The only way to inspect the keel bolts is from under the boat, usually with the boat out of the water. I have an 84 swinger that I bought last year. First order of business was to replace the lifting winch, turning ball, cable, volcano tube and keel bolts so that I would have a point of reference as to when the necessary maintenance needed to be done. Catalinadirect.com sells all the replacement parts you need to do all this.
Tags
25 ft catalina keel bolt
CAL 20 Keel bolt replacement Calabego Cal 1 12-21-2008 04:24 PM
Keel Bolt, Mirage 30 PegasusX Gear & Maintenance 0 09-05-2006 06:48 PM
Keel Bolt question catamount Gear & Maintenance 2 06-20-2005 04:36 PM
Keel bolt issue gray_williams Gear & Maintenance 8 12-05-2003 06:23 AM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
