Where to get a good deal on a new outboard - SailNet Community
post #1 of 4 Old 05-14-2009 Thread Starter
donhaller's Avatar
I live in Chesapeake Beach, MD and fairly central to all the western shore marinas and boating centers, but I don't know where to go to get the best deal on an outboard. My boat has an old 9.9 Yactwin by Evinrude that may have seen its last days. I want to replace it with something that is going to be reliable.
Any ideas?
C&C 25 MKI, Hull No. 039
donhaller is offline
post #2 of 4 Old 05-14-2009
Tohatsu makes a nice small four-stroke outboard.
sailingdog is offline
post #3 of 4 Old 05-14-2009 Thread Starter
donhaller's Avatar
I know this sounds crazy, but I have a retractible motor mount that is permanently mounted to the stern of the boat and it says "NOT FOR FOUR STROKE". I was hoping to find something in the next week or two and not have to remove and replace that motor mount if possible. I assume a new mount for a 4 stroke motor would be heavier and require filling the old holes and re-drilling. I was hoping that I wouldn't have to do any more drilling or filling for a while if possible.
Does anyone make good 2strokes?
post #4 of 4 Old 05-14-2009
The motor mount probably says that because for the maximum HP it is rated for, the four-stroke motor will be considerably heavier than the two-stroke version, and it will break under the weight and force of the four-stroke motor. Unless you're close to the maximum weight and HP for the bracket, using a smaller four-stroke on it should not be an issue. For instance, if you have a bracket that is rated for up to a 10 HP two-stroke motor or 100 lbs., putting a 9.9 HP four-stroke motor on it, that weighs over 100 lbs. is probably a bad idea. But I would be seriously surprised if that same bracket couldn't handle a 8 HP four-stroke motor that is 85 lbs.
Johnson apparently still makes a two-stroke motor. The four-stroke motors are far more fuel efficient and usually quieter than the two-stroke variants, but a bit heavier.
Updated Offshore Cruising Boat List - January 2008 sab30 Boat Review and Purchase Forum 208 03-09-2017 08:30 AM
Quiten Sailing good deal wakai Boat Review and Purchase Forum 3 11-27-2003 10:48 AM
Good Nutrition For Sailors Carol Bareuther Her Sailnet Articles 0 05-10-2002 08:00 PM
Ingredients for a Good Leader John Rousmaniere Her Sailnet Articles 0 08-27-2001 08:00 PM
Achieving Good Teamwork Downwind Dean Brenner Racing Articles 0 02-04-2001 07:00 PM
