- Quick Menu
03-05-2010
Walter
Bottom Painting advice and costs for Chesapeake Bay
Hello, I have a Catalina 30 with many years of old bottom paint. I would like to have her bottom painted this spring.
What is the best paint to use in the Chesapeake Bay?
I heard that the Chesapeake Bay has worse fouling problems (barnacles and plant growth than than Floridia!
What should I pay to have my boat hauled out of the water, the bottom cleaned and two coats of a bottom paint that will give me at least one season of barnacle-free bottom?
I do not need a racing bottom as we are not into racing.
Thank you - Walter "Parrot Bay" Catalina 30 Shoal draft
03-05-2010
Walter,
I'm not familiar with prices on the Chesapeake, but I'm going to venture a guess anyway... $1,200-$1,400 for two coats of ablative. This should include haulout, blocking, pressure wash, any scraping, prep work, painting and splashing. I would either go with what is on your boat now (if you can find out) or go with whatever your local yard suggests. They'll know.
03-05-2010
hauling out Sunday 10 miles up the Potomac from the Bay, $1K for haul, block, pressure wash, paint, zincs...unless they find something unexpected. This includes almost 2 gallons of paint, which keeps climbing in price.
Best of luck, send me an email if you want the name
dave
03-05-2010
Where in Chesapeake Bay?
The head is fresh, the foot is salt.
Do you want hard paint (so you can scrub it) or soft paint (so you don't have to scrape the paint off in a few years)?
What type of paint do you have now?
Can't answer, not knowing, but it sounds like you want an ablative (soft) paint.
I like Interlux Micron and Interlux 66 (no freshwater). I have used both several times. They are $$$ but should get you 2 years, if you haul in the winter. 18 months if you stay in the water. Whether you need to strip the bottom, can't say. Unless the paint is loose, it is not required.
Yes, the Bay is tough that way.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Reason: more info
03-05-2010
C&C Racer/ Cruiser
I am in Rock Creek. We use Micron Extra Ablative, 2 coats, extra on leading edge surfaces on the keel and rudder. Last two years with a diver going down once each year. Dont forget to get an antifowling for the prop also.
Call Oak Harbor for their latest prices. (not affiliated with them)
Dave
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
03-09-2010
Bottom painting & haulout Prices Chesapeake Bay Spring 2010
Hello Walter -- Here are some prices for paint and labor from the updated spring 2010 price sheet from the marina I use near Baltimore. They do nice work and work hard at saving their customers money instead of nickle and dimeing you!
++++++++++++++++++++ From Old Bay Marina example price sheet:
25' Sailboat or Powerboat bottom painted for $175.00 and includes taping waterline, all materials (less paint) tape, rollers brushes, etc.
30' Sailboat or Powerboat bottom painted for $195.00 and includes taping waterline, all materials (less paint) tape, rollers brushes, etc.
35' Sailboat or Powerboat bottom painted for $225.00 and includes taping waterline, all materials (less paint) tape, rollers brushes, etc.
We have the lowest prices on bottom paint - We beat West Marine's catalog prices on bottom paint.
Micron with Biolux $191.36 gal.
Act with Irgarol $99.99 $267.77 for 3 gallon pail
Vivid Free new bottom paint from Pettit only $175.00 gallon
Seacock valves and thru-hulls serviced - Reasonable rates on stuffing box re-packing, shaft and propeller service.
Cutless bearing replacement.
I must add that the marina DOES NOT sand your bottom for that price, they will Soda blast the bottom but this is very pricey at $40.00 per foot! They will pressure wash the bottom with a 4,500 PSI water blaster for free and this knocks off the loose paint and in most cases this is all that is needed for prep work --George
03-09-2010
MD's Best Boat Detailer
That is a good price but does it include sanding and barnacle removal?
Reason: Commercial Posts for services are a violation of Forum Rules
03-09-2010
Are you at Port Kinsale?
dave
03-09-2010
I'm fairly new to sailing and only have experience with one brand of paint and that's Petit Hydrocoat. Its a water based multiseason ablative. Based on talking to other boat owners around me, I'm convinced it is as effective as the higher price products and has done well in PS tests. On my previous boat we went 2 seasons with a haulout over the winter and then sold that boat. On the current boat I sanded the exisiting ablative to create "tooth" and put on two coats of Black Hydrocoat. The boat has been in the water since May of last year and was scrubbed by a diver once during the season. The boat hasn't moved since late October and currently has a 1/4" beard of slime, but no hard growth. I'll do a short haul in the spring to powerwash, check/replace zincs and repack the stuffing box and I'll be good for another season at least.
We hire a diver to do several of our boats and I don't need cleaning any more often that the guys using Micron or Interlux. Also, I used a short knapp roller then tipped with a brush and finally did a very light hand sanding and got a really smooth bottom, not racing smooth, but way smoother than a lot of boats I see in the yard.
Being a water based paint, Hydrocoat is a lot less troublesome for do it yourselfers since there aren't any fumes and it cleans up easily with water.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
03-09-2010
Commercial Posts offering services are a violation of Forum Rules
did not put an offer of services in.....just a name of who I used, please contact me if you want details....
Reason: Posts for services are a violation of Forum Rules
| Thread Tools |
Search this Thread |
