Originally Posted by ekenna
...My cruising guide did not have much. it had exactly 3 or 4 sentences about cheaspeake beach and flag harbor but did not even mention breezy point.
Once we get to the solomons does anyone have favorites/preferences. Someone said moorings are available or would you do a slip? ( I do not have shore power so mooring is ok) Favorite restuarant or sight seeing place? I figure on doing the marine museum and the lab visitor center anything else?
All three of the western shore marinas have web pages - be sure and have a look while planning and maybe call ahead if you think you may want to use one. They are small marinas catering mostly to the rod & reel set, but offer slips, and sailboats of shallow draft are common - some sailors have permanent berths there.
In Solomons: the moorings are off Zahniser's marina in Back Creek. There is plenty of room for anchoring in back of the mooring field if you choose.
If you want a slip - hail Solomons Yachting Center on the way into Back Ck. They are located just west of Molly's (or Moll) Leg Island and have a fuel & pump out pier to port as you pass north. They rent floating docks for $2/Ft. and have 1st class facilities, restrooms, baths, TV room, free WiFi, bar and pool - though the pools (anywhere) will probably not open till after Memorial Day.
The museum often hosts concerts with some well known names. Check their schedule before your trip. You may want to attend - or avoid if the music is not to your taste. The Museum is just up Back Ck from Zahniser's.
lancelot,
"I lived aboard for many years there in Solomons and still miss the place and living aboard."
Where did you keep your boat - when were you there? We probably crossed paths a few times if in the 2004-2009 range.
