Kent Narrows - Local Knowledge Needed - Page 3 - SailNet Community
post #21 of 40 Old 06-03-2010
Thanks Dee for the update. I know you go out regularly with your vessel and I suggested that your input would be valuable for others on here. Did Joe Palmeranz (sp?)put up a temp. charts of the shoaling in the marina community boards? He usually does this when he gets complaints.
FYI..'Tango' may get splashed next week..still lots to do.
Again,thanks for your input.
Clay
s/v 'Tango'
Oxford, Md.
aa3jy is offline
post #22 of 40 Old 06-03-2010
We just got back from a great sail and wanted to update the channel info. We were in the channel about 1 1/2 hours before and then 1 1/2 hours after high tide which was at 10:30 today. Wind was out of the south which tends to give higher tides than when the wind is out of the north. No problem with the depth what so ever with the 5ft 10 inch draft. We stayed toward the green both coming and going and always had at least 2.5 feet below the keel from "2" all the way to "6". After the turn at "6" and about half way to "8" I did see 2 feet below the keel whereas last week I saw 1/2 foot but that may have been in error.
We did observe something interesting prior to our return to the channel and that was maybe a 45+- foot cabin cruiser entering the "channel". It did not enter the channel but instead stayed all the way outside until it made the turn south at "5". It was not up on plane but was moving fast with the stern digging in and I thought the fellow must be drunk, but then when he turned south and entered the channel(around "5") he slowed down and continure normally. There was a Carver power boat at the fuel dock when we finally got in about 10 minutes later and I think it was the boat. The hailing port was Kent Island so if that was the boat he had some local knowledge, but I didn't get a chance to get to the dock and ask questions. Still there was plenty of water close to the green markers inside the channel so don't know why he was outside and not slowing down seems pretty questionable too. With a sailboat the grounding is really no big deal, but a power boat running at a pretty good speed will do some damage to the running gear.
lancelot9898 is offline
post #23 of 40 Old 06-03-2010
About 3 yrs ago prior to the current dredging..there where some temp.(green) bouyage that where placed on the out side of the permanent green day marks. Probably this was the course that the observed cabin cruiser was following..
Regards,
Clay
s/v 'Tango'
aa3jy is offline
post #24 of 40 Old 06-22-2010
T37Chef's Avatar
FYI,
Update: I just passed through the Narrows this past Sunday on our way from St Michaels to the Patapsco and found the depth to be fine. I kept a close eye on the depth and never saw anything less than 10' except one area near the Green 15 as you are entering the channel from the Narrows heading into the Chester I saw 8', but that shoal is clearly marked on the charts. We were at slack tide so there was little current, it was after a high tide I believe but I may be incorrect.
Shawn
T37Chef is offline
post #25 of 40 Old 06-23-2010
Originally Posted by T37Chef View Post
FYI,
The shoaling of concern is in the vicinity of Red Day Mark # 4..not sure about how your depth meter is calibrated;ie, reads depth of water from meter to ground?; depth of water from keel to ground?; or depth of water from water line to ground?
Regards,
Clay
s/v 'Tango'
aa3jy is offline
post #26 of 40 Old 06-23-2010
T37Chef's Avatar
Depth of water. I was refering to this are:
Shawn
T37Chef is offline
post #27 of 40 Old 06-23-2010
The chart you're referring to are MLLW depths..I'm referring to what you see on your depth meter and how it's calibrated?;ie; Is it calibrated to read from the sender to ground?; Is it calibrated to read from your keel to ground?; or is it calibrated to read from the water line to ground?
I for one who have been through the Narrows numerous times have seen far less water even at high tide..
aa3jy is offline
post #28 of 40 Old 06-23-2010
T37Chef's Avatar
from waterline, I like it that way
aa3jy...I'm not trying to debate the depth of the water there, just sharing my observations, take it or leave it
Shawn
T37Chef is offline
post #29 of 40 Old 06-23-2010
chef2sail's Avatar
just an observation...wouldnt it make the most sense to set the calibration from the waterline to the ground. After all the chart is for MLW which unless i am a novice is from the surface of the water (same as the boats waterline) to the ground. Why calibrate it from anywhere else. I too transit the Narrows at least 5 times a year and this spring found plenty of water in the channel at low tide.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #30 of 40 Old 06-24-2010
Point of my thesis..are we talk'n oranges and oranges..not orangutans and apples..or someday when 'someone' takes a serious cruize in waters other than the Chesapeake and that 'someone' is told the coral heads are so many feet/meters deep the information passed is compatible in 'someone's depth meter readings...before entering an unknown island harbor
Regards,
Clay
s/v 'Tango'
aa3jy is offline
Big Bend Local Knowledge? Mike Turner Florida - Western 12 06-23-2012 04:13 AM
Local knowledge Ft Walton Beach to Panama City ICW SabrinaKS Florida - Western 4 04-21-2010 03:35 AM
Local Crew Needed, Jax. Fl.....? nicholas829 Crew Wanted/Available 0 10-04-2009 01:17 PM
Moriches Inlet Local Knowledge thefantasea General Discussion (sailing related) 0 06-27-2003 07:34 PM
