10-27-2010
C&C Racer/ Cruiser
This does not sound like an alignment problem. Sounds like you have engine issues. My old Atomic 4 driven Islander 28 was rated at 30 hp not the 11 your Universal is, however I dont think the reduction in hp would prevent you from achieving at least 6 knots in flat water.. 3 knts on the gps..with or against the current? (Thats a speed over ground measurement not necessarily speed through the water. Has it always been this slow in the water? or has this gradually happened over the course of the summer?.
..I would strongly suggest you get a good mechanic to go over the engiine with you as you have presented a myriad of problem areas.
Is the Univeral (Kubota) fitted with a Hurth transmission? Is their a reduction gear for the deisel? Atomic 4 do not need one but diesels which have one and replace them need a larger prop than the Atomic 4 had. Did they do the engine replacement correctly?
Are the prop and shaft clean?...the bottom?. If I remember correctly you bought the boat this year and splashed it in the Northern Chesapeake in the spring. Was the bottom painted. Have you had it cleaned during the summer at all. There will be lots of gowth on it if you havent. Tha will slow you to a crawl.
Was the boat surveyed when you got it? My surveyor checked on the size of the prop vs the engine. Is it pitched correctly?
Troubling is that you are overheating. Is the thermostat functioning? These engines are particular to operating in the 140-160 degree range..is that where you are. Is there scale in the engine blocking the water flow.
Overheating...thermostat...black soot on the sensor,,etc.Does the engone blow any type of smoke..grey, white, bluish, black?.
Does it have a mixing elbow which may be full of carbon?. How do you know it is running at 3000 rpm with no tach. Running at 3000rpm is pretty high.
You need a professional to go over your engine with you. Let a professional look at this before giving up your ship.
Dave
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
