01-14-2012
Originally Posted by mltroy
Curious as to what is meant by "mouth of the Potomac". Is it just where the river meets the Bay? If wind and current are opposing at the mouth of the river, how far East and South do the nasty conditions extend?
Can you avoid them by crossing from say, Reedville to Tangier? Or would that put you right in the middle of it? Could you travel north on the west side of Tangier and Smith Islands or would it be better to just travel up Tangier Sound?
Thanks for any insight.
Mary Lou
Rhodes 22 Fretless
Rock Hall, MD
I think you will find that when it is nasty, both the potomac from the Birthday Cake mark (about 12 miles up the river) to the bay, as well as the bay itself can be pretty nasty. If you are transiting north south (or vice versa), you can get some relief staying closer (in the lee) to the eastern shore - but that makes watching the water much more important. Alot of the water around Tangier and Smith Island is quite thin, and even more so when it blows east west. And you lose the ability to run to a hole, if things get worse. IN a blow, perhaps a bad habit I learned way back, was to stay in the deep water with plenty of room to run, or be pushed around...there have been times that I motor, head in to the wind and waves at mid throttle - and just stay still and have control. Much better motion.
Transiting east to west or vice versa you will need to be on your toes, but as a previous poster indicated, it is a great way to test your skills. Not sure though that I would want to be in it in a small, or mostly open boat, unless you have a buddy around or onboard who can help you out.
Best of luck, and I am sure others will chime in.
