07-26-2011
Senior Culinary Member
Datswite...
When we have a destination to get to for whatever reason, we know we'll likely have to resort to motoring...its just a fact I suppose. We normally need to run the engine about 1-2 hours a day anyway to charge the batteries and cold plate. I would think if you're going to take the time to come North to Annapolis you want to spend some time there, not just one night?
If you push the first day (or two), perhaps a really early start in the dark out of you marina, I think Oxford is very doable. You would have to committed to a long day, say 12-15 hours. The suggestion in starting so early and in the dark is you would be familiar enough with your own cruising grounds in the dark, but it should get you to your new, unfamiliar, destination in daylight, which is much preferred
Lots of things to consider, if you're really reluctant to run the engine then reconsider the whole plan...if you make it to Annapolis, great, if not, you know you still had a blast
My thoughts anyway...
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
