Help -- need a prop puller in Annapolis area - SailNet Community
 3Likes
  • 3 Post By josrulz
post #1 of 10 Old 03-28-2012 Thread Starter
Unpaid Intern
josrulz's Avatar
Hi folks, I'm removing the Martec prop on our boat, and I need a prop puller. I've tried rental places, but they don't have gear pullers with enough "reach" to get around the long hub on the Martec. I tried to buy one, but none locally have the reach either.
Does anyone have a gear or prop puller in the Annapolis area that will work on a Martec? I would be happy to rent it.
Or any recommendations on where to rent one elsewhere? Any help is greatly appreciated.
Thanks!
-J
1984 Sabre 34 Mk I
josrulz is offline
post #2 of 10 Old 03-29-2012
Re: Help -- need a prop puller in Annapolis area
Sometimes pulling a prop that has been in place for a very long time can be extremely difficult to pull. We learned that the hard way. Finally resorted to pulling the shaft with prop attached by bringing the assembly to a machine shop equipped with a "bearing press" that did the job.
Dick
Flybyknight is offline
post #3 of 10 Old 03-29-2012
You should hit it with PB Blaster while you look. Can't hurt and might help a lot.
I installed a new wheel pilot and thought I might need to rent a puller to get the wheel of the pedistal since it wouldn't budge when I first tried to remove it. I sprayed it with PB Blaster a few days before I tried again and it came right off with a few taps of a rubber mallet.
If you do have to use a puller be sure to leave the nut in place lest the prop "sproing" off and hit someone in the head. (Ask how I know)
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
post #4 of 10 Old 03-29-2012
Senior Smart Aleck
jameswilson29's Avatar
Use a $14 propane torch from Wallyworld set on the lowest possible setting, a short 2" x 4", and a hammer.
The propeller will heat up and expand away from the cooler propeller shaft. A well placed piece of wood positioned around the right angle between the prop and the shaft allows you to gently knock the propeller off the shaft.
jameswilson29 is offline
post #5 of 10 Old 03-29-2012 Thread Starter
Unpaid Intern
josrulz's Avatar
Thanks guys, I've tried PB Blaster, though I haven't tried heat. The hub is only an inch from the strut, so there isn't a lot of space in there. I've tried wacking it with a block of wood and hammer. Nothing worked.
I asked the yard to remove it, and they've been too busy to get to it. I just need to get the thing off there, so I figured I'd try a puller.
The nut will definitely remain on there to stop the hub from flying off!
Thanks again...
-J
1984 Sabre 34 Mk I
josrulz is offline
post #6 of 10 Old 03-29-2012
One of None
deniseO30's Avatar
a friend in my YC had a big 3 jaw puller made by "snap on" the tool co. that sells to the automotive trade. Maybe you can rent one at a auto tool store. Big as it was it still needed "percussion persuasion" to pop.
My last project!
deniseO30 is offline
post #7 of 10 Old 03-29-2012 Thread Starter
Unpaid Intern
josrulz's Avatar
Thanks denise030, I tried Pep Boys, and the largest puller they have doesn't have enough "reach" for the Martec hub. I tried United Rentals here in Annapolis, and they don't rent pullers. So far, no dice, but I'll keep working on it.
1984 Sabre 34 Mk I
josrulz is offline
post #8 of 10 Old 03-29-2012
One of None
deniseO30's Avatar
Maybe a heavy equipment garage? Mechanics can be very helpful when you tell them what great tools they have.
DON'T MISREAD THAT! lol
My last project!
post #9 of 10 Old 03-29-2012 Thread Starter
Unpaid Intern
josrulz's Avatar
I wouldn't touch that with a... OK, I'm going to stop typing now.
1984 Sabre 34 Mk I
josrulz is offline
post #10 of 10 Old 03-29-2012 Thread Starter
Unpaid Intern
josrulz's Avatar
Update: The prop is off!
I wish I could say I located a puller. In fact, I located a guy at the yard who ended up having to use a puller, blow torch, a pipe, and a mallet to get the thing off. It wasn't going to come off easily.
Thanks again for the input anyway. I appreciate it!
mgmhead, chef2sail and wingNwing like this.
1984 Sabre 34 Mk I
josrulz is offline
Best surveyor in Annapolis area? mmcdan Gear & Maintenance 12 06-25-2014 10:52 PM
Annapolis Area Surveyor AndrewMac Boat Review and Purchase Forum 5 10-20-2009 11:01 AM
Acme Harmonic Prop Puller? SEMIJim Gear & Maintenance 13 07-11-2008 10:31 AM
looking for S2 7.3 in Annapolis area NomadPa S2 1 09-18-2006 11:59 AM
DC/Annapolis area phowson Crew Wanted/Available 2 05-18-2006 11:40 PM
