Mechanic? - Page 2 - SailNet Community
post #11 of 32 Old 04-30-2012 Thread Starter
sv Cordelia
Nicklaus's Avatar
Re: Mechanic?
Forgive my ignorance of inboard engines (hence the need for a mechanic), but to answer your question... I don't know.
I crawled under my sink to check it out and it appears to be one of the lower, aft bolts that holds the manifold to the engine block. What I couldn’t tell was where it actually broke. Since part of the bolt came out, I am assume the piece that needs to be removed is in the engine and not the manifold. If that’s the case, then it couldn’t be drilled out on a work bench.
Nicklaus is offline
post #12 of 32 Old 04-30-2012
Re: Mechanic?
Have to remove the manifold to get to the broken stub. Then the drill and easy out if it's broken flush to the block. May not be easy but can't tell till you see it up close.Then call for help. Maybe new bolts all round and careful not to over torque to the correct pattern. Learning new skills makes boating more fun.
Capt Len is online now
post #13 of 32 Old 04-30-2012
Chastened
Ajax_MD's Avatar
Re: Mechanic?
Ok, this may not be too bad then, Nick.
You remove the other bolts and remove the manifold. The remainder (stub) of the broken bolt should be easily accessible. You soak this in a penatrent called "Kroil". The stuff is AMAZING. Then, we can put some tools on the stub and twist it out.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #14 of 32 Old 04-30-2012 Thread Starter
sv Cordelia
Nicklaus's Avatar
Re: Mechanic?
Thanks for the help. If I can get out to the boat before the mechanic, I think I'll give it a try or at the very least give him a head start.
Nicklaus is offline
post #15 of 32 Old 04-30-2012
travlin-easy's Avatar
Re: Mechanic?
If the bolt is broken off flush with the engine block, there's no sense in removing the manifold. However, if there is a stub sufficient enough to grasp with vise-grip pliers, then remove the manifold, soak it with Liquid Wrench, or Kroil for a couple days, then heat the block with a a propane torch. When the block around the bolt is fairly hot, grasp the bolt stub with the vise-grips and carefully work it back and forth until it loosens. This sometimes works well, and sometimes the bolt will break right at the block.
If that happens, the next step requires drilling the center of the bolt with a drill-bit that's slightly smaller than the bolt diameter. This takes a steady hand so you don't get off center. Once the bolt has a nice, clean, relatively deep hole in the center then you can insert an easy out. However, I would recommend again heating the block with a propane torch--this can make a world of difference.
Most of the bolts used in the Atomic-4 were mild steel, so they should drill fairly easily. Once the bolt is removed, it's a good idea to chase the threads with the same size tap that was originally used to tap the block. Before inserting the new bolt, you may want to use a good quality, thread lubricant on the bolt so you don't have the same problem in the future. And, if you have to remove the manifold, replace all the old bolts with new ones that are also lubricated as well.
Good Luck,
Gary
travlin-easy is online now
post #16 of 32 Old 05-02-2012 Thread Starter
sv Cordelia
Nicklaus's Avatar
Re: Mechanic?
Well, heard from the mechanic today. And of course it's never good news.
Apparently my A4 block has a hole in it.
Nicklaus is offline
post #17 of 32 Old 05-02-2012
Seņor Member
PorFin's Avatar
Re: Mechanic?
Um, how'd we go from replacing a broken manifold stud to finding a "hole in the block"? What kind of a hole, and where is it?
You might want to consider getting a second opinion...
PorFin is offline
post #18 of 32 Old 05-02-2012 Thread Starter
sv Cordelia
Nicklaus's Avatar
Re: Mechanic?
I'm going to head out and take a look tonight.
Will try and post pictures tomorrow, but I would ASSUME it's behind the manifold.
And, the second opinion brings me back to my original post for good mechanic suggestions...
Nicklaus is offline
post #19 of 32 Old 05-02-2012 Thread Starter
sv Cordelia
Nicklaus's Avatar
Re: Mechanic?
Went out there after work and nosed around. I examined the area where the manifold was and took a couple pictures - attached here - where the manifold was attached. Since that was the original problem, I assumed that's where my mechanic found the holes.
Granted, I don't really know a dang thing about Atomic 4s aside from the fact that mine hates me and has since I bought my boat last year, but everything looks normal to me.
Stopped by a local bar / restaurant. Asked the bartendar if any mechanics come in there. Left my number for one she said comes in every afternoon for a drink on his way home. Maybe he'll call tomorrow.
Nicklaus is offline
post #20 of 32 Old 05-03-2012
Re: Mechanic?
If you had taken the manifold off your self you'd have a better idea of the scope and problem. Is there a 'hole in the block'? Doesn't look like it.Do broken studs need drilling and easy out? Should replace the remaining stud at the same time.Will chasing out the threads and new studs properly installed with new gasket cure the issue? Maybe a second or third confirmation would help .This is not rocket stuff. Or trust the guy to install new Isuzu and gear and learn the love the little bugger.
Is this mechanic trying to pull one over on me? Mariner777 Gear & Maintenance 14 06-25-2011 07:02 PM
Mechanic lyonsian General Discussion (sailing related) 19 05-16-2008 08:54 PM
Diesel Mechanic in NC mhfowle Gear & Maintenance 2 10-24-2006 08:24 PM
Unhinged mechanic jswwrites Gear & Maintenance 11 10-02-2006 02:07 AM
Mechanic from hell sailingketch Irwin 2 08-08-2006 03:17 PM
