Is Ch 27 automatic radio check dead in Tochester? - SailNet Community
post #1 of 10 Old 06-09-2012 Thread Starter
Could not raise it last weekend. Is it my radio or doesn't it work anymore?
MastUndSchotbruch is offline
post #2 of 10 Old 06-10-2012
Re: Is Ch 27 automatic radio check dead in Tochester?
Ch 27 worked today 6/10/12 in Rock Hall.
ronbo1 is offline
post #3 of 10 Old 06-11-2012 Thread Starter
Thanks.
Hm, will try to call it again today.
post #4 of 10 Old 06-11-2012
Tartan 27' owner
CalebD's Avatar
Sounds like you might have a VHF problem.
Ch. 27 worked fine this weekend in Annapolis.
Everybody has one:
CalebD is offline
post #5 of 10 Old 06-11-2012 Thread Starter
Thank you.
It may be time to retire the 15 year old VHF...
The SH with built-in AIS looks mighty attractive
post #6 of 10 Old 06-13-2012
travlin-easy's Avatar
Might a corroded antenna connection(s). VHF radios are really tough, and most of those on sail boats are not exposed to the elements like those aboard power boats. Consequently, they seem to last forever. Use a multimeter and check the connections before shelling out the money for a new one. I though mine dropped dead while at the rendezvous, stopped at west marine and picked up a new one today. While removing the old one the radio suddenly came to life. Turned out to be a corroded crimp connection on the negative power line. I removed both crimps, soldered and heat shrinked the connections, and my 15-year-old VHF still works like a champ.
Good Luck,
Gary
travlin-easy is online now
post #7 of 10 Old 06-13-2012 Thread Starter
Good Luck,
Gary
I do admit that I suspect an antenna connection. It has been on my 'check out' list for some time.
But where would then be my excuse to buy one of the cool new models with integrated AIS ?
post #8 of 10 Old 06-19-2012 Thread Starter
You were dead right! I checked the antenna connection (in the bilge) and it was badly corroded. Re-soldered it and got a beautiful signal from Tolchester Radio!
[yes, I know a connection in the bilge is not ideal. Will have a more permanent solution at some time...]
post #9 of 10 Old 06-20-2012
chef2sail's Avatar
If its in the bilge can you make it waterproof by getting some of the shrink electrical tubes you use for crimping connections and make it waterproof.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #10 of 10 Old 06-20-2012 Thread Starter
Dave
You are right. I should do a better job on that.
On the list for the next visit to the boat...
tx
Tags
communication , radio check , sea tow , vhf
Radio check Minnewaska General Discussion (sailing related) 94 06-30-2011 09:04 PM
Automatic Bilge Trouble Perithead Gear & Maintenance 9 09-06-2010 07:54 PM
Automatic lifevest Sixbrothers Gear & Maintenance 28 06-08-2007 01:44 PM
AIS (Automatic Identification System) admin Gear & Maintenance 2 02-13-2006 12:57 AM
Radio Check jdkirkk General Discussion (sailing related) 8 04-21-2005 09:29 AM
