Need To Hire A Local "Up The Mast" Person - SailNet Community
post #1 of 15 Old 11-04-2012 Thread Starter
swampcreek's Avatar
My jib/roller furling is stuck up and I can't get it to budge. I need to get it down since we're hauling out November 16th. I took pictures of the top of the mast to see if anything was tangling up there with the halyards but all looks good. I need to have someone go up there and find out what's going on. Are there any recomended people that handle this type of stuff local to the Pasadena area?
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
Many, many power boats
Life should be an adventure, not a guided tour!
Not all of us in the herd are sheep.
swampcreek is offline
post #2 of 15 Old 11-05-2012
chef2sail's Avatar
Re: Need To Hire A Local "Up The Mast" Person
This may sound dumb not infering you are. Have you unfurled your sail...by hand. Will the furler rotate around the headstay. When you bought the boat was the furler already on> Is there another cam cleat...maybe on the mast for the jib Halyard? Everything looks ok in your picture.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #3 of 15 Old 11-05-2012 Thread Starter
swampcreek's Avatar
The boat came with the furler already rigged, it rotates fine, the rope clutch was all the way open with the jib halyard having slack to where it enters the mast.
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
post #4 of 15 Old 11-05-2012
chef2sail's Avatar
And after you pull the sail all the way out you cant drop the jib? I know youve used the furler so the top swivel works too. That sucks. Is it wire to rope halyard or all rope? Must be hung up inside the mast or it has come off of the sheeve. Doesnt look like anything is wrong at the top in your pictures. I dont know anyone other than Annaplis riggers who go up the mast, We have snall guys at our club who do it here, but I dont think they would go elsewhere. Check Oak Harbor?
Dave
Parkville, Maryland
Our blog-
post #5 of 15 Old 11-05-2012
Tartan 37C
T37SOLARE's Avatar
The Schafer 2100 roller furler that Catalina put on the C-320 has a design defect that the lower bearing can freeze up, I've seen it on a few 320's as well mine. Call Schafer and they will sell you the re-designed unit at cost ($140). Here is a good write-up on the procedure to replace the unit or call your rigger to do it. http://www.mammothcondos.com/2100-c320.pdf
SOLARE
T-37 #442
T37SOLARE is offline
post #6 of 15 Old 11-05-2012
Senior Smart Aleck
jameswilson29's Avatar
Why don't you climb the mast and investigate?
I use ascenders and a climbing harness to scale the mast.
It appears you could tie a line to the jib halyard, then release it from the furling equipment. I assume either the halyard is jammed or the furling equipment is stuck in place.
jameswilson29 is offline
post #7 of 15 Old 11-06-2012
To pick up on Chef2sail's point: we have a jam cleat just below the mast exit plate for the jib halyard. Even when I lift up the clutch on the cabin top, the sail won't come down.
The boat is still new to us and I always forget it's there because it's obscured by the stackpack. It was good for a brief moment of panic when I had my wife up the mast in the bosun's chair and couldn't lower her back to the deck a few weeks ago.
zeilfanaat is offline
post #8 of 15 Old 11-06-2012 Thread Starter
swampcreek's Avatar
The jib rolls just fine, it just won't budge when trying to pull it down. I really am uncomfortable with the idea of going up the mast since I don't have the equipment, I've never been up a mast and at 245lbs I'm not sure it would do the boat any good having that kind of weight up there. I really think the halyard jumped off the pully and is wedged. The other 2 halyards work fine so it isn't tangled in them.
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
post #9 of 15 Old 11-07-2012
chef2sail's Avatar
OP is a big guy like me, even taller. Would be an effort to get him aloft ( Sorry) smile)
Is the halyard all rope or wire rope? Sounds like it jumped the sheeve.
No jam cleat?
If you have someone else go up. Try and combine projects and replace bulb, tape spreader boots etc. It probablky wont take a lot of time to fix your problem.
Parkville, Maryland
Our blog-
post #10 of 15 Old 11-07-2012 Thread Starter
swampcreek's Avatar
I'm 99% it's all rope...At least I don't see any wire.
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 07:50 AM
Time to delete "Local boat buying assistance"? SPC Boat Review and Purchase Forum 9 02-28-2012 11:09 PM
Chicago Area Marinas -Bleg for "Local Knowledge" sidmon General Discussion (sailing related) 7 05-01-2010 01:54 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
