-   Chesapeake Bay (http://www.sailnet.com/forums/chesapeake-bay/)
-   -   Rock hall? (http://www.sailnet.com/forums/chesapeake-bay/96069-rock-hall.html)
AirborneSF 01-25-2013 11:03 AM
Rock hall?
I was looking at a chart going into Rock Hall and was wondering, do you all go around the mud/sand bar to the south, or can you cut across? Also, I don't see any channel into a dock, I'm guessing this is NOT the case. Is it just not shone clearly? Thanks.
chucklesR 01-25-2013 11:17 AM
Re: Rock hall?
If you are talking Swan Point Bar, it obviously depends on draft.
In my Gemini (2 foot draft) I went over at the range lights. Most of my friends go around to the #2 can.
Once in RH do not try to shortcut across the center as it's very shallow, do the loop to get to the dock you want.
AirborneSF 01-25-2013 11:49 AM
Re: Rock hall?
Kinda what I thought looking at it. You went across S.P. bar?
chucklesR 01-25-2013 12:18 PM
Re: Rock hall?
I've always gone across the bar at the two yellow range marks. Never had less than 5 feet under my keel (7 feet actual). I stay within 30 feet of a straight line to the south side of the towers. My chart shows that as being a maintenance channel with 6-7 feet.
Keep in mind the Gemini draws 22 inches with the motor down.
I've been followed across by a Sabre 34 and a Catalina 27 - both drawing 4.5 feet.
The only drama I've had was when my motor quit half way over one day. How fast can you replace a fuel pump?
Donna_F 01-25-2013 12:26 PM
Re: Rock hall?
We keep our boat at Gratitude, at the entrance to Swan Creek, and we frequently see boats cutting across the bar. Other than having minimal draft, we couldn't figure out how they were getting across and the path they took (we always noticed from down around GC3 where we have to make the turn so they were probably in their docks by the time we got up there). This helps clear it up. We've only ever seen one boat grounded in that area and it was a 22 footer that had to wait for the tide.
RichH 01-25-2013 01:34 PM
Re: Rock hall?
Im @6ft+. On a high tide I usually, in calm water, go on a course of 270 'FROM' RED #4 (RH entrance buoy). I usually 'check it out' carefully in the beginning of each year.
If not 'benign' then all the way 'down' to GC3
chef2sail 01-25-2013 04:43 PM
Re: Rock hall?
We always opt for GC3 and do not cross the bar. Whats a few extra minutes. I have seen a few people stuck on it.
There are two parts to Rock Hall,
One is Rock Hall Harbor which is 47 degrees from the R4 Nun off to the starboard. No real anchorage area. There are some nice marinas and the Watermans Restaurant there
The other area and more popular is Straight up to the R6nun to the entrance of a winding narrow channel back to Swan Creek. Just take your time and stay between the bouys as they meander.
Somewhere on the starboard side as you come in around GC11 you will see mooring for Swan Creek marina and they can be rented also.
Make sure you go all the way to the GC15 before you turn to port into the Swan Creek anchorage area and feel your way back. It is shallow, but very doable. You will find more room back further as it gets shallower and kind of stay in the middle, but you can go back a long way. We draw 4.8 and have no problem. There is a conch blowing at sunset in the anchorage
Also if you turn starboard after passing R14 there is a narrow channel back to three really nice marinas.
pdqaltair 01-25-2013 04:50 PM
Re: Rock hall?
I always go across the bar, generally a little further north; at low tide I have seen as little as 4'6". South of the range mark, Chuckles is correct, except at very low tide.
There is some very shallow water inside the harbor, mostly well marked but stay close to the marinas around the outside to be safe. Not a hazard, just something to watch.
I draw ~ 3'4"
Yamsailor 01-25-2013 05:02 PM
Re: Rock hall?
After Hurricane Sandy, I would not take any chances. I would go through GC1 and GC3 at minimum.
AirborneSF 01-25-2013 05:06 PM
Re: Rock hall?
Thanks all. I think he needs to get some current charts, I know he has Boat US, and tow ins.
