Ready To Go Back In? - Page 9 - SailNet Community
 22Likes
post #81 of 112 Old 03-17-2013
Re: Ready To Go Back In?
Spent yesterday doing the 8 yards of topsoil and mulch, so we went to the slip today, since they put the boat in Friday.
Genoa on, bimini up, springlines added, bikes in the shed, heater on, batteries charged, lifelines tightened...we're ready to sail!
When I get back from California in two weeks....
Hey, bright side is, I'll be good to go!
BCC1 is offline
post #82 of 112 Old 03-17-2013
T37Chef's Avatar
Talking Re: Ready To Go Back In?
Looks like you'll be in before Shawn...hes still poking around
Dave
Hey, thats not totally acurate...we're now members of MYC and got our slip assigned today...or should I say we got our first pick of a slip. Brian, good to hear your project is coming along, you will be very glad you did this. I am, and 8 years later I have found no signs of blisters. (I do see places my first coat of paint has released itself, apparently the "bond" wasn't good.)
I will admit, I didn't plan as well as I could have but this weather isn't cooperating either. Its hard to compound the hull when its freaking snowing. My wife and I are off all week and hope to get most everything thats needed to splash the boat.
One of my poor planning examples was not throughly checking out my power washer prior to Saturday, it started right up, but a return line needs fixing = no pressure, so washing the deck of two years of grim will have to wait arrggg.
The engine install is about finished. The panel needs to be mounted and the water heater need its heat exchanger lines connected, otherwise its about finished. Prior to the install I painted the entire engine area and installed heat/sound barrier, re-routed wires, will install all new bilge hoses (damn hose is $$$), new bilge blower, and water heater (Raritan 12 G)
The rudder should be back on this week and the pedestal should be ready tomorrow after a fresh powder coat in bright white. I purchased the rebuild kits (brake & bearings) from Edson which I will do later this week.
Tuesday I have a Marine Electrician coming to help me diagnose some issues I'm having since the old engine was removed. I'm thinking its related to a ground wire or something, but I can't figure out. I want to reconfigure the house bank set up but they may have to wait.
Refrigeration is also going to have to wait a while, I want to get sailing. Although I have decided on a Sea Frost system, great systems and will fit our box perfectly with their cold plate freezer box they practically custom build.
I need to hook up the bilge pumps and anything else so we're ready to splash soon/April 1st! The rest can wait!!!! Maryland folks, we need some weather god assistance here!
PS...c2s/Dave doesn't even have his cover off yet, bawahahahaha
Shawn
T37Chef is offline
post #83 of 112 Old 03-17-2013
TakeFive's Avatar
So today was a little more productive than yesterday. The chilly temps around 40 still somehow felt warmer than yesterday since the wind wasn't so bad, and it was dry. I got my new anchor light installed with LED. Since the mast is down and the masthead plug is about 15' from the socket, I had to rig a temporary battery to illuminate the LED and verify that I had the polarity correct. I wasn't up to playing the 50-50 odds after raising the mast!
I also got the entire hull scraped, so no loose paint left. A little sanding this week and with some luck I'll be painting by the end of the week. As I mentioned in another thread, I ordered paint from Jamestown today.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #84 of 112 Old 03-18-2013
chef2sail's Avatar
Covers not odff because it snowing right now
However I have dewinterized the engine, runs like a champ and all she needs is to throw her winter covers off, rinse out the water systems, but the bimini and 135 on for now, so Ill be slowing down. I need to get a diver also as I am sure i have a bit of slime.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #85 of 112 Old 03-21-2013
Originally Posted by SolSailor View Post
I really gotta move!!! With 3 feet of ice and nearly as much snow-cover, I can only dream of working on the boat for now.
I feel your pain.
Flybyknight is offline
post #86 of 112 Old 03-23-2013 Thread Starter
swampcreek's Avatar
I really wanted to paint the bottom today, ended up spending 11 hours at work so no go. If the temperature reaches 50 degrees tomorrow I'll go for it. Minimum application temperature on instructions state 50 degrees, they're predicting 47 so maybe 3 degrees off wouldn't hurt. Moday they're predicting the possibility of a couple inches of global warming but I'm hoping they're wrong. I really would like to see it warm up, this cold weather and my insane schedule are really making it tough to do the few things I need to do.
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
Many, many power boats
Life should be an adventure, not a guided tour!
Not all of us in the herd are sheep.
swampcreek is offline
post #87 of 112 Old 03-23-2013
TakeFive's Avatar
Pettit Vivid is good down to 40, so I got a coat on yesterday and a coat on today. I want to do a third coat on the waterline and leading edges, and also need to paint the pad areas and transom hung rudder (which is in my basement right now), but I'm out of paint. So it looks like Defender will be getting an order for a quart. It really stings to pay almost half what a gallon costs, but I don't want to have a bunch of extra paint sitting around for 2 years, so it will have to be a quart.
I met the owners of the large powerboat that's blocking me in, and they're splashing April 5. I think I'm gonna go in right after them on the same day. I have a few important things to do first, like raise the mast.
TakeFive is offline
post #88 of 112 Old 03-23-2013 Thread Starter
swampcreek's Avatar
At work we are teaching a whole new Lock Out Tag Out procedure to almost 700 people, they want this done by May 1st. Most of my Saturdays could very well be tanked until then. Hopefully I can take off during the week if there are any holes in my training schedule. I think after this is all over and the boat is in the water I might need a small vacation, I joked in an email to my wife about going to Jamaica, she emailed me back stating she'd pack and meet me at the airport...I may consider this.
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
post #89 of 112 Old 03-25-2013
TakeFive's Avatar
These are stored on Facebook, so not sure they'll show up here unless you're logged into your account:
First pic is before painting, with the sanded bottom and masked boot stripe:
The second pic is after applying new bottom paint. Also note that I raised the mast:
TakeFive is offline
post #90 of 112 Old 03-25-2013
chef2sail's Avatar
Looks good Rick
I didnt realize you dont have gunnels and that you lifelines are essentially on the coachroof. Your jackline (s) when you put them in if you follow the lifelines actually will almost be centerline to the boat like I was taught.
Most sailboats stachions and lifelines arent configured like yours. I understand your set up now.
Dave
Parkville, Maryland
Our blog-
Ready, Set, Sail: America's Cup Back In Rhode Island NewsReader News Feeds 0 06-27-2012 10:00 AM
Sailing: Wild Oats clinches back-to-back victories (New Straits Times) NewsReader News Feeds 0 12-28-2006 08:15 PM
Back to school means back to the schedule (The Palm Beach Post) NewsReader News Feeds 0 08-16-2006 03:15 AM
Boaz sails to back-to-back titles (Sand Mountain Reporter) NewsReader News Feeds 0 04-28-2006 10:15 PM
