Cockpit Sole Reinforcement - SailNet Community
post #1 of 5 Old 4 Weeks Ago Thread Starter
1964 Columbia Challenger
I have been meaning to post, and this already may be a "given"- last time the boat was out of the water and while doing a goodly amount of work to the hull (glassed in all thru-hulls save for the cockpit drain) I installed a 2x3 in the middle-ish portion under the cockpit sole, spanning athwartships between the locker walls, lag-bolting from inside the lockers, utilizing some 5200 and wood shims to fill in gaps and it has been a great help in "flex" of the sole and is much stronger, currently.
Hope this helps another Challenger/24 owner that weighs more than 100 lbs!
BTW- if anyone want to daysail, in SoCal area, I am out in the San Pedro Channel around 35 times a year (most Sundays).
Huff
64 Challenger
LA CA
Huffboat is offline
post #2 of 5 Old 4 Weeks Ago
Re: Cockpit Sole Reinforcement
What kind of wood did you use? Did you glass it in, seal it or leave it bare?
Jeanneau 54DS
Minnewaska is offline
post #3 of 5 Old 4 Weeks Ago Thread Starter
I just used a scrap piece of doug fir (pine), "on end", bare, but it could be glassed in, or a different species of wood used, if ambitious. That area under the sole stays pretty dry. The only other recommendation I should offer up is that I angle-cut the ends just a a couple of degrees to match the taper, looking down, of the sole. It was all pretty easy and very effective.
Hope this helps.
Huff
64 Challenger
Huffboat is offline
post #4 of 5 Old 4 Weeks Ago
I would seal it up well. At a minimum, I would coat with penetrating epoxy, if out of direct sunlight.
Jeanneau 54DS
post #5 of 5 Old 4 Weeks Ago
Huffboat: Your approach sounds much better than many of the facockta "solutions" that sailnetters offered when you originally inquired.
Hudsonian is offline
Paint for cockpit sole? colsen Gear & Maintenance 9 06-29-2015 06:52 AM
Cockpit sole repair Boomer14 Gear & Maintenance 5 11-08-2014 05:43 PM
Cracked Cockpit Sole jetdrvr393 Gear & Maintenance 15 04-14-2012 12:29 AM
new core for cockpit sole Grcesq Gear & Maintenance 10 11-17-2009 05:18 PM
Is the cockpit sole cored? timangiel Gear & Maintenance 10 05-11-2007 10:32 AM
HTML code is Off
