new rudder on a columbia 24? - Page 2 - SailNet Community
post #11 of 26 Old 01-28-2009
Somewhat Flexible Member
ssneade's Avatar
dude's looking for shoe, should have answer by next monday. can you send pics of lazerette and companionway hatches when you are finished? if i see what i have to do, i can usually do it..........
Self Proclaimed Genius
ssneade is offline
post #12 of 26 Old 01-28-2009 Thread Starter
Yeah I will. I'm almost done with the forward hatch so that will be the first pic.
tbeagley is offline
post #13 of 26 Old 02-01-2009
ssneade's Avatar
hey tbeagley, take a look at this and see if it will suit your needs. think it came from a challenger. looks just like mine.......
ssneade is offline
post #14 of 26 Old 02-01-2009 Thread Starter
Thats it! Now the question is how can I get my hands on it and how much will it cost? I finished the forward hatch, take a look.new rudder on a columbia 24?-tads.domed.hatch.cover%5B1%5D.jpg
tbeagley is offline
post #15 of 26 Old 02-01-2009 Thread Starter
This is the hatch that was on the boat when I rescued her. You don't have to go with the curved top if you wanted to keep it simple. But If you wanted to go the route I went this is how I did it: After measuring the opening that the hatch was going to sit on, then I determined how high I wanted the hatch and how much of a curve, I tried to make the curve to complement the curve of the cabin. I made a rough cut a few inches longer than I needed for two pieces of half inch marine grade plywood. I found the center and measured off the bottom 2 3/4 and and 1 1/2 on both sides. Then i drove a nail at the high center point and bent a flexible strip of wood to each end and traced the curve. I cut the curve with a jig-saw (both at the same time) and used a belt sander to smooth the curve. Then measuring from the center to both ends I cut them the right length and screwed the two 1 1/2 side pieces on. Next I squared it and screwed on the top piece of 1/2 plywood on top. Then I measured the length of the curve (only a strong 16th of an inch longer) and cut the sides on a table saw on a 5 degree bevel. I glued and clamped the 1/4 inch oak plywood on top, traced out the 3/4 oak for the sides and mitered them together ( I had to take some scrap pieces and try out the angles to get them right) I used a brad gun to attach them, then counter-sunk screws and used plugs so you cant see them. The 3/4 oak is an inch lower so it covers the raised lip of the opening. I mostly pleased how it came out. Now I have the rear and companionway to do. This is a pic of the hatch that was there.new rudder on a columbia 24?-tads.sailboat.11%5B1%5D.jpg
tbeagley is offline
post #16 of 26 Old 02-02-2009
ssneade's Avatar
thatzanice! you have patience that outmatches mine, and also must own better woodworking equipment. ya know, you could make some good side dough making them for other boat owners. that's how i pay my slip rent and upkeep on my boat, by doing mechanical and electrical side jobs. anyways, if you want, call me @678-477-1462 (cell) between 800 am and 700 pm or 770-893-2341 (home) between 400 and 700 pm and we'll work out specifics. how about 20 bucks, and you pay s&h?. couldn't be much ups ground or even usps. gimme a yell..........
ssneade is offline
post #17 of 26 Old 02-07-2009 Thread Starter
Just a thought, I am going to have an extra companionway hatch when I'm done with my new one. Its fiberglass and not in bad shape. Also, I'm looking for a portside window (the big long one) if anyone knows of one.
tbeagley is offline
post #18 of 26 Old 02-14-2009
ssneade's Avatar
hey tad, sorry for the delay, i've been caught up in life as usual. i'm gonna ship that thing today via ups. i'll email you with a tracking number.............
ssneade is offline
post #19 of 26 Old 02-22-2009 Thread Starter
I got it yesterday. Fits great! sent my check out on tuesday. Thanks again scott.
tbeagley is offline
post #20 of 26 Old 07-11-2009
I am a contender 24 owner which translates to a contender "restorer" and also have a need for a rudder cup or gudgeon cup if anyone knows where to find another one? Also is there some method for sealing around motor&venting when mounted in the lazarette? Has anyone had any luck in replacing long style cabin windows? I am inspired by photos of everyones obviously hard work...makes it seem alittle more worth it now!
Poorboat is offline
The New Columbia 30 PracticalSailor Buying a Boat Articles 9 08-15-2010 06:58 AM
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 02:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 08:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 08:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 08:00 PM
HTML code is Off
