Aura Col 30' - Change Prop? - SailNet Community
post #1 of 3 Old 03-11-2009 Thread Starter
Aura Columbia 30
We own a 1984 Aura Col that when purchased came with a folding prop. We are new to sailing and the previous owner suggested purchasing a fixed prop. The limited use we got last season showed us that she reverses like a 3 legged dog - the previous said it is largely due to the folding prop.
Opinions? He said that I could sell the folding one for a fair bit and easily replace it with a new fixed one with the cash from the sale. She is on the cradle now... so now is the time to do it if I am going to !
thanks.
Boondoggle30 is offline
post #2 of 3 Old 03-11-2009
lbdavis's Avatar
A fixed prop will certainly improve performance in reverse when compared to a folding prop. There are many concerns with folding props including: not having all the blades unfold - quite the racket!!
A fixed three blader will give you good performance in both forward and reverse, but will increase drag significantly from your folding prop. This will be your cheapest solution.
A feathering prop will offer you increased performance in forward and reverse and still have little drag. However, it does require a second mortgage on your house.
Good luck!
S/V Gracie
P303
lbdavis is offline
post #3 of 3 Old 03-11-2009
As alternatives to the michigan wheel 3 blader, consider the Campbell Sailor prop (2 or 3 blades) or the Kiwi feathering prop - which also has had some good reviews and costs much less than the Max and Jprop featherers.
West by North Enterprises
The link is for the distributor, they ship worldwide.
Faster is online now
Seafarer 26' prop shaft replacement jkimberly Gear & Maintenance 5 02-17-2009 11:04 AM
Prop Change terryjoe Gear & Maintenance 8 09-02-2008 10:08 AM
Changing prop underwater trantor12020 Gear & Maintenance 16 03-03-2007 12:02 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 07:00 PM
HTML code is Off
