Go Back   SailNet Community > Boat Builders Row > Columbia & Coronado
Old 04-08-2010
Flightsport's Avatar
S/V Jackfish Girl
Flightsport is on a distinguished road
Where to get portals for C26T
I am about to rebed the port lights in my Columbia C-26T. In the event that something breaks (ie frame), does anyone know where I can get of this exact size? Its a 1977 C-26T. Thanks!
Mike
Old 04-08-2010
Jeff_H's Avatar
Super Moderator
I think you mean either Portholes, or Port lights (some times spelled Portlites and sometime simply called Ports). If your C26 is a Catalina, Catalina is still in business and you may be buy some parts directly from them or their OEM suppliers. If your boat is a Cal 26 things get harder indeed. That said, very often the frames on portlights are reusable. You can often replace the lenses with Lexan or Plexiglass and on operable ports the gaskets are often available as well.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 04-08-2010
S/V Jackfish Girl
Thanks Jeff. Its a Columbia C26T, vintage 1977. I've been hesitant to do this rebed job for fear of breaking something and ending up with a larger problem. I have another post in the maintenance section asking for suggestions on rebedding and/or replacing. Thanks. Mike
HTML code is Off
C26 leaking portals Flightsport Columbia & Coronado 7 06-16-2010 04:06 PM
Leaking Portals... Flightsport Gear & Maintenance 12 04-08-2010 10:51 PM
BCNG Portals Page (Red Deer Advocate) NewsReader News Feeds 0 09-11-2006 06:15 PM
